 Post subject: Garry, EFI LIVE Problems
PostPosted: Sun Sep 16, 2007 12:31 pm
Garry
Wondering if you have version 6.XX of EFI LIVE. I upgraded to version 7.4 and lost capability to flash 98 PCMs right now . Plus my PCM is frozen because of it . Thank goodness I had a back up but its got a stock flash in it.
PostPosted: Sun Sep 16, 2007 12:47 pm
Never had a 6.x version ... 7.2 or 7.3, whatever it was 18 months ago...
No feedback from Ross or Blacky after sending the debug info?
PostPosted: Sun Sep 16, 2007 2:49 pm
The debug reports only told them that it an interruption occurred or something like that.
I would like to try that version , to rule out software .
PostPosted: Sun Sep 16, 2007 3:19 pm
I have 7.3.2, which is on the CD that came with EFILive ... should probably be the same that you have ? Let me know if you need it ...
PostPosted: Sun Sep 16, 2007 4:39 pm
I jusr found a copy on one of old thumbdrives . It didn't work. So I believe it to be in the wiring from the OBDII connector to the computer.
Hopefully it is something simple.
PostPosted: Sat Sep 22, 2007 9:58 am
I should have a few old versions about too. Not v6 though. Let me know if you want me to email you a link or zip file.
PostPosted: Sun Sep 23, 2007 7:09 pm
Hey Ram
I found the problem . It was the the female pins in the diagnostic port that were slightly distorted for some reason. Thanks anyways.
PostPosted: Tue Sep 25, 2007 7:36 pm
10-4 glad its sorted.
