It is currently Tue Sep 29, 2026 11:53 am
 Post subject: ******John******* need some info
PostPosted: Sun Dec 09, 2001 10:07 pm
I just got my dyno bat and the mount for it. First of all, that is a real sweet piece, but when I saw it, the first thought I had, was does this tiny thing have enough ass to start the car?
Have you had any cranking problems? Also, this thing is the perfect size to hide in the drivers side rear space where the subwoofer is. Do you think this would produce enough amps to turn the car over given the extra distance, and the fact that I'm under driving the alt?
thanx, and BTW, I found the elusive drain plugs for the FLP's, you need any?
PostPosted: Mon Dec 10, 2001 9:47 am
Rob I could use the drain plugs, thanks! As for the batt it's a kicker. From other folks that have it have reported no problems. I have it mounter where the spare tire use to be. I keep a optima in the garage just in case though. Had for bout 6 months w/ no problems. It'll fire right up on 1st crank but since my pump is going south it takes a few hits before kickin in.
Just send me the parts and the bill and I'll mail you the check.
PostPosted: Mon Dec 10, 2001 12:16 pm
you sure you dont want to keep the spark plugs in there? :) J/K!!! no problem, I'll send 'em out.
PostPosted: Mon Dec 10, 2001 7:25 pm
Thanks Rob! :)
John Silas
PSC 2 Box 10786
APO AE 09012
