 Post subject: Double oil filter relocating kit
PostPosted: Wed Nov 28, 2001 11:05 pm
I want to relocate my oil filter. At the same time I also want to add another filter to my car for a couple reasons, 1 better filtering, 2 another quart of oil. Does anyone know a company that makes this kit for the LT1. I'm trying to avoid any oil problems from ever destroying my engine again. :( moment of silence)
PostPosted: Thu Nov 29, 2001 4:08 am
If your pulling your engine, just put on a 7qt oil pan. Also think about installing a ignition/fuel cutoff switch that will shut the engine off if oil pressure drops below 5-7psi (about 12 bucks).
I would think that would be more efficiant than a double filter, and alot easier to find room to install.
PostPosted: Thu Nov 29, 2001 8:56 am
I thought of the cutoff but I've never found a place that makes one for the LT1. I'm going to go with the moroso 7qt oil pan with the double baffles ment for course racing for over here. I was mainly looking at the double filter to bring my car up to 9qts instead of 8qt. I know it's only a quart but I figured it may save somthing incase of. Thats a good idea on the cutoff but do you know where to get one. I called jegs about the one they have in there magazine but they said it wouldn't work on newer f-bodys?
