Page 1 of 1
[ 12 posts ] |
fbody97
Post subject: just currious Posted: Sun Dec 09, 2001 9:50 pm |
Joined: Mon May 28, 2001 7:29 pm Posts: 1175 Location: fairfield, CA
Any of you guys know the cost and/or power gains achieved with converting to a sollid roller cam? If this was brout up before, I appologize. I tried a search on cz28 and came up dry. The only thing I have heard is they are more maintenance, but I would like to know more. We are talking next winter at the earliest, I am mostly currious.
_________________ Dave Brooks
Robert13p3h
Post subject: Posted: Sun Dec 09, 2001 10:03 pm |
get used to adjusting valve lash. Maybe some performance bennies, but the non-stop valvetrain adjusting would get old pretty fast IMO.
99taws6
Post subject: Posted: Sun Dec 09, 2001 10:09 pm |
If I am not mistaken don't you have to pull the engine to remove a valve cover on a LT1?
guerardsgt
Post subject: Posted: Sun Dec 09, 2001 10:56 pm |
George Smart azz  Dave you'll have a headach about once a month as Rob Stated. You have to pull both valve covers bring your number one piston to top dead center and adjust all odd cylinders somthing like that I can't remember what cylinders it is exaclty. Then you'll have to roatate the assembly by hand 360 degrees and adjust the rest. You also may have to pull the intake off to get the right tension on your push rods. There really isn't enough finger room to check from the heads. If you over tighten you just bought yourself a new cam because you'll wear down the journals on the camshaft. If it was me I wouldn't do it. That just opens up to many chances to replace stuff. Just my 0.2 cents.,
My96z
Post subject: Posted: Mon Dec 10, 2001 1:00 am |
I was reading up on this also. Seems that if you want big power, solid roller is the way to go.
Aside from taking the covers off of a LT1 its pretty easy to adjust valves, just start the car with the covers off, loosen the valve till it clacks, slowly tighten it till it stops, then 1/4 turn more. I imagine a solid roller is adjusted the same way?
My dream motor is a solid roller:)
fbody97
Post subject: Posted: Mon Dec 10, 2001 1:03 am |
So basically you are talking about stepping up to a race only setup. I'm still currious how much more of a power gain this would give.
Going out on a tiny limb here but I don't apreciate that email George based on your comment here. I don't clog the board and you know it.
99taws6
Post subject: Posted: Mon Dec 10, 2001 7:58 am |
Quote: Going out on a tiny limb here but I don't apreciate that email George based on your comment here. I don't clog the board and you know it.
I know you do not Dave... I sent it out to all registered users... You are not guilty.....
guerardsgt
Post subject: Posted: Mon Dec 10, 2001 10:35 am |
I thought I was the only one who got it. Although I will admit I did over post just a little. It was still a nasty little e-mail though. That's alright what ever doesn't kill us will make us stronger.
Hawk
Post subject: Posted: Mon Dec 10, 2001 5:52 pm |
How come I did not get it?
RT1
Post subject: Posted: Mon Dec 10, 2001 7:47 pm |
Joined: Mon May 28, 2001 7:46 pm Posts: 1091 Location: El Paso, TX
Well that is prolly why you are back to being a lowly 'Senior Member' instead of one of those cool 'No Lifers'. Bad, evil, posters.
O and Bruce, this conferms my theory, of your e-mail addy doesn't work. That is why we keep getting those errors when you don't take that check mark out of the send a message block.
RT1
Jr
Post subject: Posted: Tue Dec 11, 2001 6:37 am |
hmmm.. I never saw a message like that either....
guerardsgt
Post subject: Posted: Tue Dec 11, 2001 3:55 pm |
I want to get another one of those so I'm going to post till I get back the posts i've lost. J/k
Page 1 of 1
[ 12 posts ] |
Users browsing this forum: No registered users and 54 guests |
