 Post subject: Paging Jamey, isle 12..Need some info
PostPosted: Mon Dec 24, 2001 3:00 am
I saw in your mod post, that we have the same line loc. Can you give a rookie alittle info on were the lines go, and how you hooked up that 5lb bag of wires.
.......please.........
TIA
PostPosted: Mon Dec 24, 2001 9:38 am
What all wires does it come with? Mine you just hook to a ground, then one wire to the switch. The other end of the switch hooks to power.
The lines goes from the front of the Master Cylinder to the line loc, then from the line loc to the ABS unit.
