It is currently Wed Sep 16, 2026 2:23 pm
 Post subject: Help needed on 1.6 RR's ...
PostPosted: Fri Jan 18, 2002 1:48 am
I've seen new self aligning 1.6 ratio RR's (Comp cams magnum) run about $170 but also at $260 for the PRo version.
What is the difference ?
I need new RR's (1.6 ratio) for my Lt-1 as i'll be using the 306 cam most likely.
The heads already are fitted with Lunati dual springs that provide plenty of lift.
Now, can anybody tell me the difference between the cheaper and more expensive RR's ? Anybody have an adress for cheap RR's ?
According to most the GNHP rr's are pretty good aswell and don't cost the world, anybody ?
Thanks,
Sergio
PostPosted: Fri Jan 18, 2002 2:57 pm
I didnt spend alot of time researching this, and I've always wondered if there could be that much diff between the big companies. So I cant help much, except if it comes from Comp or Crane it cant be all bad. IMHO
