It is currently Mon Sep 14, 2026 1:18 am
 Post subject: SS suspension question...
PostPosted: Wed Oct 02, 2002 9:46 pm
What size sway bars does the 96/97 SS come with? Rob made a comment about them being stock but aren't they bigger than Z28 sway bars? I thought it was 32mm/27mm(or something)??? Thanx in advance, Mike
PostPosted: Wed Oct 02, 2002 10:42 pm
LOL, the 'ol SS complex strikes again. J/K :).
I'll let somebody else chime in, but if its not a 1LE or a stage II(or however its called) SS, then.........
 Post subject: Rob...
PostPosted: Thu Oct 03, 2002 12:34 am
That is cool man, I was not sure. Thanks, Mike
PostPosted: Thu Oct 03, 2002 3:23 am
seriously, if you have the stage II suspension, which I have no idea if you do or you dont??? Then you have a larger front swaybar, but same rear. If you dont, then you have the same setup front and rear. Its the 1LE's that get all the choice auto x stuff.
But hell, the way your throwing coin around. Get you a set of Hotchkis or BMR and be done with it :-ok:
PostPosted: Thu Oct 03, 2002 5:33 am
It should be 32/19.
But you can easily check with a set of open end box metricwrenches
PostPosted: Thu Oct 03, 2002 7:58 am
My sway bar is the laeger 1LE but its hollow. Panhard bar is also 1 LE variety.
 Post subject: Thanks guys...
PostPosted: Thu Oct 03, 2002 12:26 pm
I will check...:)
