 Post subject: Suggestions for a new Cam
PostPosted: Fri Sep 27, 2002 12:35 pm
Well I'm looking into getting a new cam for the ride but don't know what size or brand to get...... Any suggestions would be helpful..... and the lopeier the better.....and no I do not have a stall converter yet. Thanks in advance for all of the help. Later!
PostPosted: Fri Sep 27, 2002 2:05 pm
You are going to need a convertor for any cam worth a crap. But you should be able to get away with a LPE 211/219 grind, it what willis used to have in his car when he was here, it was almost as lopey as my hot cam but smaller and does not need a custom tune. But I have the hotcam and I like it, best bang for the buck, but you will need a tune to get maximum benefit from it. I am pretty sure I remember you have most of the bolt ons. Go with a convertor, that will be your biggest gain and the next best step, A vigilante is pretty much guarenteed to knock at least .3 off your time and will set you up for a cam change. Vigilante is exspensive but worth it, its bulletproof and comes with one free stall change.
You can get away with as big as a CC 306 on stock heads they say, and will lope like a SOB.
PostPosted: Fri Sep 27, 2002 5:52 pm
I have an xtra cc305 if your interested and it uses stock rockers and stock computer tunning. It'll definatly make your car have quit a bit of bump and lump. Let me know it only has 603 miles on it i'll sell it for $120.00 and the vavle springs you'll have to buy yourself but there only $80.00 through thunder racing. Let me know.
PostPosted: Fri Sep 27, 2002 6:14 pm
I heard this thing last winter in Ryan's car. Sounded very nice with a very noticable lope. Later.
PostPosted: Sun Sep 29, 2002 8:34 pm
Ryan let me check with the wife as soon as she gets back... but don't sell it until you hear from me ok...... thanks man!... also one last thing what are the spec's on the cam (intake lift ... exhaust lift... ect..)
 Post subject: Jr...
PostPosted: Mon Sep 30, 2002 5:52 am
Just a thought, Bob gets his cams custom grinded and can have one done for your applications as well. It will be more than $120 but just letting you know. Let's try to hook up this weekend. Later, Mike
PostPosted: Mon Sep 30, 2002 5:39 pm
Mike,
Sounds good to me I'll talk to you about all of that this weekend. Shoot me a call sometime DSN 722-1310 ( ask for Sgt Preston) or you can call my house..... 919-759-2435. Later.
 Post subject: you awake still?
PostPosted: Tue Oct 01, 2002 4:01 am
just curious if you were online....
PostPosted: Tue Oct 01, 2002 6:32 pm
Awake huh????
 Post subject: Jr / Mike
PostPosted: Sat Oct 05, 2002 4:22 pm
Jr the Cam is a CC305 224 intake 230 exhaust 114lsa not sure of the lift at this moment. I'm pretty sure those specs are correct the cam is just a little bigger than the Hot Cam.
Mike- Wait till you hear what I have under the hood now ??? OOOOOOOOOOOlotoooooocash:) the wife was actually very supportive.
