 Post subject: Brakes
PostPosted: Thu Jan 22, 2004 6:51 pm
Anyone ever converted LT1 brakes to LS1? Strano says they are a lot better, for cheap.
Any inputs?
PostPosted: Thu Jan 22, 2004 10:22 pm
I haven't but the rotors just slip on and off and the Powerslot rotors are cheap but you'd need the calipers off the LS1 as I think they're twin piston and the LT1 is single piston (correct me if I'm wrong!) but the caliper bracket is obviously longer as the discs are 11.8" compared to the 10.9" of the LT1.
PostPosted: Thu Jan 22, 2004 10:37 pm
Yes the LS1s are duel in the front and single in the rear.
PostPosted: Thu Jan 29, 2004 12:41 pm
i have mine done if you would like to feel it you could drive i can actuate my abs on dry ground at 40 mph now
1994 t/a
PostPosted: Thu Jan 29, 2004 6:16 pm
I'll take you up on that Predator
PostPosted: Thu Jan 29, 2004 6:45 pm
when ya want to do it
1994 t/a
PostPosted: Thu Jan 29, 2004 6:46 pm
call me right now within the next hour at 0678368498
1994 t/a
