 Post subject: Best Rear Diff. Fluid???
PostPosted: Thu Aug 23, 2001 10:00 am
Just a little question to all of you guru's out there.... I have to replace a rear wheel bearing in my 96' Z... I have the performance axle with the 3.23 gears and posi trac. What I'm wondering is what fluid (besides the GM type that is outrageously expensive) is the best to use.... I have heard that MOBIL 1 75-90W SYNTHETIC is the best... does anybody know though???? Thanks!
PostPosted: Thu Aug 23, 2001 10:57 am
Jr
As long as it meets The Gm specification it will work. Also don't forget about the 3oz. bottle of friction modifyer.
PostPosted: Thu Aug 23, 2001 11:23 am
Yeah that little bottle is costing me about as much as the fluid will..... Thanks!!! By the way what is GM'S spec's if you know off had I think it just has to be a type of 90W
PostPosted: Thu Aug 23, 2001 11:32 am
I dont know what the best is **cough Redline cough**, but for the most part, oil is oil so just grab some gear oil out of AAFES (its in that ugly black bottle).
the additive, shouldn't cost more than $10 or 20dm at the german dealerships, and dont replace the seal everytime either, just seal it with RTV
PostPosted: Thu Aug 23, 2001 12:30 pm
Do I only need one bottle of additive or 2?? I was olny planning on doing the RTV anyways they want way to much for the seal..... I wish I could get redline... but A. the wait is to long and 2. I haven't been able to find anyone to ship it over here.,.. they say it's not safe to ship on a plane or whatever! What a load of crud. Well if anyone knows how much additive I'll be a happy camper!
PostPosted: Thu Aug 23, 2001 12:36 pm
1bottle of additative only.
PostPosted: Thu Aug 23, 2001 12:46 pm
Rock on!!! I was looking around today for a the lube and I found a German Synthetic Oil 75-90W for automatic Trans. Do you think that will work if I add the additive with it?
PostPosted: Thu Aug 23, 2001 1:08 pm
Dexron III ATF is differant than hypoid gear oil.
You will need about 2qts of gear oil and 1 3oz bottle of additive, GM part #1052358
When you decide to change the fluid in your transmission, then Dexron III ATF is a good choice, and you will need about 4qts for that.
PostPosted: Thu Aug 23, 2001 1:11 pm
So just about any typew of gear oil is good right? I was thinking of going to 80-90W because that's about the only type I can find......
PostPosted: Thu Aug 23, 2001 6:19 pm
I know that I am getting ready to do mine so I will just use the Quaker State Gear oil for GM rears that they sell at the Auto Parts Store. It is in a green bottle. I am also of course going to use the additive.
PostPosted: Fri Aug 24, 2001 6:09 am
Woah.... they have gear oil over there??? I can't find it anywhere over here... I think I'll have to take a trip down to Ramstien this weekend!!!
PostPosted: Fri Aug 24, 2001 11:24 am
Yeah they just don't carry full synthetic. However speakin
w/ the aafes guy they did say if we give them the part #
and enough people request "cough" FBE they can stock it.
So what do you guys say? I have the part/model # sittin
in my wallet........;)
