It is currently Tue Sep 29, 2026 11:11 am
 Post subject: No driving in D or 3 gear 93 3,4 Firebird
PostPosted: Sat Sep 15, 2007 3:06 pm
Hi,
I hope that I'm right in this area. My 93 Firebird 3,4 is not driving in the D or 3 gear. In R 1 and 2 the car is driving normally. What could the problam be?
Daniel from germany
PostPosted: Sat Sep 15, 2007 3:43 pm
What does the transmission fluid look like and smell like?
PostPosted: Sat Sep 15, 2007 3:59 pm
i'm not sure, looks red but i think it smells a little bit burned. if is not smelling burned, are there more than one problem? the car has about 180tmls on the clock
PostPosted: Sat Sep 15, 2007 6:56 pm
Best way to tell about the fluid is compare with a sample of new fluid.
Look for discoloration , burned smell, and shiny particles. If you can siphon it out of the pan would be best.
PostPosted: Wed Oct 17, 2007 10:31 am
first thing i would do is flush the old chit and replace the filters. then go from there! thats no more then probably 50$ and with a 180K its probably worth it.
1993 Z28;A4,.008shavedheads,Borla Adj catback,CAI,3.73 gears,Trick flow Elbow,Taylor 8.2 wires,NGK plugs,Pacesetter,UMI brackets,Spohn LCA, Spohn panhard,ZR1's
http://www.fquick.com/towshen
Users browsing this forum: No registered users and 17 guests
