It is currently Sat Oct 24, 2026 2:01 am
 Post subject: no fuel to the engine
PostPosted: Mon Oct 04, 2004 10:41 am
can someone give any advice on what to do on my situation I've changed the two fuel injectors, fuel pump, fuel filter and the ecm and im runnig out of time and money please help its a 92 camaro rs 305. And am I the only one who thinks the opel/chevy dealer in homburg is a rip off ???
PostPosted: Mon Oct 04, 2004 10:56 am
No you're not- they suck!
PostPosted: Mon Oct 04, 2004 10:57 am
Can you hear the fuel pump run for about 3 seconds when you turn the key on? If not, check the fuel pump relay. If it is O.K. then check the voltage to the fuel pump at the wiring harness attached on the left side underneath the car above the rear coil spring. If it has voltage then the fuel pump is bad. If the fuel pump runs then check the lines coming out of the tank. Sometimes when you change the pump you can actually crimp one of the lines when you re-install the tank. I did it on someones car and luckily we found it before trying to start the car. Hope this helps out.
PostPosted: Thu Jan 27, 2005 8:19 pm
hi, if u need fuel injectors I've got all 8 for a 5.0 TPI . They are stock, 19lbs. They have been used for about 6 months. I'll sell them for about 70$.
http://www.cardomain.com/id/unexplained666
CHEVROLET- Cheap, Hardly Efficient, Virtually Runs On Luck Every Time
PostPosted: Thu Apr 13, 2006 5:30 pm
What a BRAINER!
The guy has a RS TBI..............
PostPosted: Thu Apr 13, 2006 7:36 pm
Dude , chill out a little bit. We are a friendly bunch here.
PostPosted: Fri Apr 14, 2006 12:43 am
What a BRAINER!
Yeah man! I don't think anyone ever ripped on you like that.
