It is currently Sat Oct 24, 2026 2:53 am
 Post subject: horn dome fuse keeps blowing
PostPosted: Sun Oct 24, 2004 6:45 am
hello every one. I finally got my 92 rs to run. 602 eur later with a new ecm & ignition control module my 305 tbi came alive, but of couarse the problem does not end there. Im having a problem with my horn fuse blowing out, would any of u have any idea where to start to trouble shoot and find the short
 Post subject: Re: horn dome fuse keeps blowing
PostPosted: Sun Oct 24, 2004 3:22 pm
You could disconnect the horn and put another fuse in and see if it blows. If it doesn't blow then you have a short to ground in the horn. Also you can check to see if there is a short in the steering column. Looks like you are going to be chasing this thing around. Try to get a wiring schematic and chase the wires and see if they are grounded some where. Hope that this helps.
Best 1/4: 13.587 @100.90mph
PostPosted: Mon Oct 25, 2004 1:47 pm
I have the same problem mine blows every couple of hours. If I swap the blown fuse the new one holds a little while then blows. I cant find where or what is making it blow.
Owner JZ Customs
Binsfeld GE
