It is currently Sat Oct 24, 2026 2:53 am
 Post subject: Water Pump, short or long style?
PostPosted: Wed Oct 12, 2005 10:24 am
Hi,
Somebody know if on a 1991 z28 5.0L TPI it's a short or long style water pump?
I'd like to buy an edelbrok water pump but I don't know which to buy for my car?
I think I have a long style.
If someboy can help me,
Thank you very much
ALBORZ
1991 Z28 V8 5.0L TPI TH700R4
PostPosted: Wed Oct 12, 2005 7:57 pm
I think that I found. It's a long style.
ALBORZ
PostPosted: Wed Oct 12, 2005 8:16 pm
that sounds right but I wasn't sure so I didn't say anything.
I know somebody here would know.
PostPosted: Wed Oct 12, 2005 9:19 pm
Thanks for website,
I wrote to summit racing, they write me this :
The difference between the long or short water pump is very easy to determine. Simply check to see if you can fit your fingers between the waterpump and the timing chain cover. If you can, you have a long waterpump, if the clearance is too tight to fit your fingers in there, you have a short waterpump
That's why I thing I have a long style water pump,
Thanks again
ALBORZ
PostPosted: Wed Oct 12, 2005 9:40 pm
I have never looked at it that way I just remeber looking at them while they were off the motor.
PostPosted: Thu Oct 13, 2005 2:06 pm
It is a long style. Short pumps were used alot in the 60s and 70s. Here is something you need to know. If your car has a serpentine belt system then you will need to get a water pump specific to that. Serpentine belt systems spin the water pump in the opposite direction as a regular V-belt system. I am pretty sure yours is the serpentine system.
PostPosted: Thu Oct 13, 2005 2:15 pm
EDL-8881 should be the right part number from Summit Racing for your water pump. Long style that fits 87-95 year 305 engines. It rotates counter clockwise for the serpentine system.
PostPosted: Thu Oct 13, 2005 2:36 pm
nx is the man
PostPosted: Sat Oct 15, 2005 5:10 pm
WOW!!!
It's exactly this number Item Image
I'll change my serpentine and pulley with my water pump Image
I ordered a sets to TPIS
But I don't know it this is well for my car, I'll try.
Somebody have try it?
Thanks very much for your help
ALBORZ
