It is currently Sat Oct 24, 2026 1:59 am
 Post subject: Dumb Door Question
PostPosted: Fri Jan 06, 2006 10:07 pm
I´ve got another question.
Car´s in winter sleep and i fix some minor glitches.
One of is the driver door.
The door drops some inches if it is opened and it looks like the door-suspension is worn out.
I tried to get the door off to change the faulty parts (thanks to Chilton) but i´m really fu**ed that all the electronic stuff in the door has to be deconnected to get the door off.
Two questions:
- Do you think there is a easier way to change the parts ?
- Any tips how to get the "hold the door open" spring off or better: How to get that think back on without the spring removal tool mentioned by Chilton´s ?
Thanks, Tom
P.S.: New pics will come soon...
Executer
1991 Camaro RS 5.0 TBI - Back in Black
V50 for the kids
PostPosted: Sat Jan 07, 2006 8:38 am
Never did a third gen door, But I always keave the door fully open, sometimes I have to remove the front fender to get at all the door hinge bolts . I support the dorr from underneath , Remove the bolts and then remove the door with the help of an assistant.
 Post subject: Finally...
PostPosted: Thu May 11, 2006 11:01 am
It took a while but it worked.
The replacement-pin comes with a small bushing, that can be replaced if the door is removed.
I also changed the break pads and was almost screaming about the allen screws at the breaks. Not metric.... Aaaaah...
How often do you guys replace your oil and ignition wiring / sparkplugs ?
I only drive about 5000 miles a year (summer / good weather car) and did it three years ago, but it feels like the engine is idling a little bit out of the round.
Executer
V50 for the kids
PostPosted: Thu May 11, 2006 12:09 pm
For the amount of miles you drive yearly. Once year on the oil. Plugs are cheap to buy than test. Ignition wires you can test with a ohmmeter. your distributor and rotor are probably the culprit most likely.
 Post subject: Re: Dumb Door Question
PostPosted: Thu May 11, 2006 7:37 pm
The door sagging is a common problem with the f-body. The doors are very long and play havoc on the bushings. Get used to it, it will never go away! I know, I have had 3 f-body's and they all had the same problem.
Best 1/4: 13.587 @100.90mph
