It is currently Wed Sep 16, 2026 1:59 pm
 Post subject: 3.4 Dyno sheet needed!
PostPosted: Sat Oct 27, 2001 1:19 am
Hello,
I desperatly need to see a dyno sheet from a stock (or nearly) 3.4 V6 car. I am working on a custom fuel injection project and I need to see the torque curve to extrapolate the volumetric efficiency of the engine.
Any info would be appreciated!
Thanks
Nathan Acree
PostPosted: Wed Nov 07, 2001 1:02 am
Since we don't really have dynos here, check http://www.camaroz28.com or http://www.fbody.com
PostPosted: Wed Nov 07, 2001 3:27 pm
And the dyno's we do have don't do torque!
PostPosted: Tue Nov 13, 2001 9:32 am
In fact they don't even do the horse power reading correctly!
PostPosted: Tue Nov 13, 2001 9:47 am
... which is kind'a funny, as the HP value is usually derived from the torque IIRC ...
PostPosted: Tue Nov 13, 2001 1:04 pm
I believe the formula is
HP/5252xRPM = Torque
and the formula for horsepoweris
torque x 5252/rpm= horse power
I may be wrong but I think this is it.
PostPosted: Tue Nov 13, 2001 1:15 pm
Try this
http://www.gm.com/automotive/gmpowertrain/engines_cartruck/other/34_torque.htm
PostPosted: Tue Nov 13, 2001 1:43 pm
your math is spot on as usual Roy.
But really HP is not measurable, its a number.
the only thing that does get measured is Torque, and HP is just extrapolated from there.
PostPosted: Mon Nov 19, 2001 5:30 am
Thanks for the info guys!
I checked fbody.com and such before I posted here. I simply could not find anyone who had their 3.4 on the dyno.
Anyway, thanks to the person who posted this link
http://www.gm.com/automotive/gmpowertra ... torque.htm
I believe the curve is from an aluminum head 3.4 from a Pontiac Grand Am or a derivative, and is slightly different, but close enough for what I need.
Anyway,
Thanks!
Nathan Acree
New Mexico USA
