It is currently Mon Aug 24, 2026 10:08 pm
 Post subject: OSL site ...
PostPosted: Wed Dec 05, 2001 12:41 pm
OK, the new domain was registered yesterday and as of this morning is active ... if you still have osl.fbodyeurope.org somewhere on web pages or your bookmarks, please update to:
http://www.osl-racing.de
I will be adding an info page soon, but right now, both still work the same ...
PostPosted: Wed Dec 05, 2001 3:33 pm
I can't get it to work?
PostPosted: Wed Dec 05, 2001 3:39 pm
Thats because nothing good works here at work!
PostPosted: Wed Dec 05, 2001 4:26 pm
Let me guess - you can't get to fbodyeurope.org directly, either, but use the other URL I posted? Same old problem ... need to get that fixed some time ...
PostPosted: Wed Dec 05, 2001 5:15 pm
Just tried myself and could not get it to work from home.
Zac (The Virgin 97 TA)
PostPosted: Wed Dec 05, 2001 5:16 pm
Doesn't work at home either. :roll:
PostPosted: Wed Dec 05, 2001 5:19 pm
Nope, doesn't work for me, either!!
PostPosted: Wed Dec 05, 2001 8:09 pm
Garry I need some of that magic you did for this other site same problem @ work
PostPosted: Wed Dec 05, 2001 8:46 pm
I've set it up under http://osl-racing.de, too, with the other IP address ... that should work out ...
PostPosted: Wed Dec 05, 2001 9:57 pm
NOPE...
PostPosted: Thu Dec 06, 2001 6:37 am
Nope still no worky... worky!
PostPosted: Thu Dec 06, 2001 8:55 am
Of course it does help to put the right address on the board ... not .org, but .de ... corrected above, try again ...
PostPosted: Thu Dec 06, 2001 10:50 am
Doesn't work here...
PostPosted: Thu Dec 06, 2001 6:17 pm
Gary I plan to get the jump on Jack on this other board. Hook me up first and ban Jack J/K LOL
PostPosted: Fri Dec 07, 2001 8:27 pm
OK, after getting off the phone with Bruce, I guess there is a functioning fix for the access problem ...
For all you military guys not being able to reach either FBE or OSL site, change the settings of your browser to use this address as your proxy server: 195.158.42.11 port 8080
I have set it to accept accesses from any army.mil address ... if you cannot use this proxy, send me the output of this command via mail: ipconfig (I need the IP address ...)
PostPosted: Fri Dec 07, 2001 8:51 pm
The military keeps blocking out the site... First http://www.fbodyeurope.org worked, then it was blocked. Then ww2.fbodyeurope.org worked, it to was blocked.. Then the IP #'s worked... They are now blocked... I can go to porn all damn day, but I cannot check the board.. What is up with these damn computer nerds?
PostPosted: Fri Dec 07, 2001 10:19 pm
I am posting away thanks Gary
PostPosted: Fri Dec 07, 2001 10:50 pm
Am I the only one with a completely dumbfounded look on his face? :-dunno: ww2 still works here.
PostPosted: Fri Dec 07, 2001 11:52 pm
I can't find the message board.
PostPosted: Sat Dec 08, 2001 9:46 am
/openbb after racing will take you to the board.
