Page 1 of 1
[ 5 posts ] |
Hawk
Post subject: Rear diff Posted: Sun Dec 30, 2001 10:36 am |
Does anyone know what the difference between 3 channel and 4 channel ABS, I am pretty sure I have 4 channel What size are the u-joints, and what are the exciter rings? any info you can give me on this stuff I would appreciate.
Sergio-Casino
Post subject: Posted: Sun Dec 30, 2001 4:18 pm |
Joined: Mon Jun 18, 2001 8:49 am Posts: 334 Location: Den Helder, Holland
3 Channel ABS is when the ABS sensing for the rear is done by just 1 sensor which works with that refluctor ring. So it just senses that the diff stops turning, wether that is caused by the left or right wheel is not possible to see.
This is the case on ALL cars without TCS/ASR
Cars with ASR/TCS have a sensor on each rear wheel just like on the fronts and the ABS can sense each particular wheel and see which one is locking up.
The problem with some after market rear ends is that most don't have a location for these sensors and making them yourself is too hard.
The 3 channel ABS only requires one hole in the diff and in combo with that refluctor ring you can make it work again (like most rear ABS system used on cars).
That's what i understand.
Sergio
Hawk
Post subject: Posted: Sun Dec 30, 2001 4:28 pm |
Thanks that made sense. I guess I have the Torsen diff which is a little diffrent and no ASR.
Robert13p3h
Post subject: Posted: Sun Dec 30, 2001 5:56 pm |
just spouting off here, but I dont think the key to the 3 vs. 4 channel abs is in the differance between a torsen and a auburn diff. But like Sergio says in the TCS/ASR/ brake system, and the sensor mounts on the rear end itself.
Dark Angel
Post subject: Posted: Wed Jan 02, 2002 10:38 am |
Joined: Sun Aug 26, 2001 4:51 pm Posts: 681 Location: RAF Lakenheath, UK
Yep, that's the difference. I have ASR. No sensor in the diff houseing, but 1 at each wheel.
_________________ Dark Angel is ready to rumble!!!!
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 5 guests |
