It is currently Tue Aug 25, 2026 5:00 pm
 Post subject: SLP set-up clutch came in!!
PostPosted: Wed May 01, 2002 12:52 pm
Looks like a nice piece. Well Roy, are you going to be ready? I plan on going to Nurnburg Friday. So think we can manage saturday at Mainz Kastel?
PS Still no luck on the autotap. I took the Ed Wright pcm out,got the VIN off of it and used it but I get the same results:( I am going to try with the original pcm next.
PostPosted: Wed May 01, 2002 1:03 pm
Good deal. You get the alum or steel flywheel?
Well we finally are going to cross paths again after 1 1/2 LOL. See you friday Jeff. Hey did you see my post in the club section as far as rendevous?
PostPosted: Wed May 01, 2002 1:47 pm
Ready when you are . Shop opens at ten . Iplan to be there by 9:30 . That way you are guaranteed #1 slot 99% of the time.
PostPosted: Wed May 01, 2002 4:46 pm
I'll be there bright and early.
I just stuck with my stocker flywheel. I did get the light weight pressure plate and it does feel lighter than the stocker. So this baby should rev with the 4.10's!
PostPosted: Wed May 01, 2002 5:26 pm
Time for a new pic, Jeff!! :p
