It is currently Fri May 01, 2026 7:03 am
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Sep 25, 2002 7:06 pm
What have you done to the T/A? What did you run? I wish I could know what my car will run.
The time are not impressive. I have a 305 with 145,000 miles on it. Now remember times are realy $hitty. First off I ran 16.5 on motor alone. Second run with power adder 15.0. You probably want to know what kind of power adder. Well it's a 75hp shot of the GO/GO juice.
Best 1/4: 13.587 @100.90mph
PostPosted: Thu Sep 26, 2002 8:20 pm
I just wonder what it will co with a custom program and a built 383?
Did I tell you I am satisfied with my Power that I have My focus will be safety this winter do not need no more power next year. I like the streetable factor I have drove it 15000 miles this summer.
PostPosted: Thu Sep 26, 2002 9:53 pm
I had better traction when the track was warm.
PostPosted: Fri Sep 27, 2002 11:26 am
Well we are going to find out next year how it all fits together. I should be around 450 to 470hp at the motor(without the GO/GO juice). We will see.
You need to start looking a safety. You have the mph down(138 is fast for the 1/4). You just have to get those 60ft times down. If you hook, I bet you will be in the 10's.
PostPosted: Fri Sep 27, 2002 12:47 pm
I agree, 10s are definitely in sight for the Hawk! Do you have a torque arm Hawk? Did you remove the front sway bar?
PostPosted: Thu Oct 03, 2002 7:31 pm
yes to both questions Lowering springs and stock shocks are alowing the front to settle this is causing me to spin above 6000 in 1, 2& 3. V 6 springs with hals and rear drag bar should solve the problem. Trying to find a set of weld draglights skinnies up front and 10 in drag ET slicks out back. when I put the roll cage in I will put the battery in the trunk also a couple other weigt transferring thingy's
PostPosted: Thu Oct 03, 2002 7:41 pm
Kewl, check ebay for those wheels. They usually have some people selling stuff at great bargains! ;)
PostPosted: Thu Oct 03, 2002 7:45 pm
Thanks if you see som let me know. I will have a set of street ET's for sale at that point.
PostPosted: Fri Oct 04, 2002 2:46 am
Hawk, first of all, good job running mid 11's. But, 138mph and your only running mid 11's?????? The 9 sec cars arent running much faster. You definatelly have a case of to much vs. not enough.
The time has come my friend, to $hit or get off the pot. Do you want to run the numbers? Then set your car up for it. If not, than I dont see any better than low 11's for your car.
If you relocate the battery, than you have to have a shut off installed. Also with your times, if they are up on the rule book, your looking at a 1 layer suit at a minimum. Also if you install a 6pt, than by NHRA rules you must have a 5pt harness if your car is faster than 12 flat. BTW those must be recertified every 2 years, or replaced. And the last rule I feel like spitting out, is that a window net is required on all cars trapping 135mph or more, or ET of 9.99 or better.
Once again great job getting your middle 11's.
PostPosted: Fri Oct 04, 2002 6:38 pm
Thanks & Yup you are right trying to have the best of both worlds though. Tony told me to slow down or put a roll cage in before next year. He said roll cage is required above 135MPH does not matter times. I know there is a change for 10.99 and quicker? I know it is a fairly new change But I do not plan to run 9's I will be happy with 10's So I plan to put Hals in with V6 spring a BMR Drag launch bar and roll cage however having problems understanding the rules and what is required. I think the MPH will drop if I get the wheels up but I really do not care at this point I want to run 10's next year and drive it everyday except in the rain.
PostPosted: Fri Oct 04, 2002 9:15 pm
Thats how they get ya. The major changes happen as soon as you run the 9.99. The least of which is the 9 sec lic you'll need, and I bet it would be almost impossible to get over there. The problem for you is the 9.99et, OR 135mph+ traps. Either way you'd be screwed. Tire wise, I think your good, cept might think about a taller tire. The traction is there if the suspension is. The drag radial class is full of 8sec cars, but they have billion dollar ultra trick 4 or 5 link suspensions.
Possible a dual stage on the gas. ie 50-75 out the gate, and another 100 about 2-3sec later when you have solid traction.
You have mad power, just need to find a way to control it.
PostPosted: Fri Oct 04, 2002 10:47 pm
I did a 150-175 hit @the lights and did not lift problem was 6000-6800 RPM's and trying to move the 3800lb car foward. Thanks for the advice I know those tires are sticky cause I launch @ 4800 I get the initial transfer and then loose it and the wheels spin above 6000.
PostPosted: Mon Oct 07, 2002 9:48 pm
I got the plan for high 10's @ 130 and still streetable. It will be a wheels (plural) up launch.
PostPosted: Sat Oct 12, 2002 9:11 am
Man you should be wheels up now! :)
PostPosted: Sat Oct 12, 2002 10:29 am
That would be nice From the video I have seen it looks like it wants to but does not.
PostPosted: Sat Oct 12, 2002 8:19 pm
I know, it should not be too hard with the correct setup.
PostPosted: Sat Oct 12, 2002 9:20 pm
we shall see 03 I know I am pushing steetability.
PostPosted: Sat Oct 12, 2002 9:29 pm
Insane....that is what the Hawk is!!
PostPosted: Sat Oct 12, 2002 9:36 pm
Thanks to the hoopty I am willing to push it a bit more this year it was primary means next year it will be primary on the nice days. Check out stars and stripes tommarrow.
PostPosted: Sat Oct 12, 2002 9:37 pm
why?
