It is currently Tue Aug 25, 2026 1:11 am
Post new topic Reply to topic  [ 105 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Cleaning the shed
PostPosted: Mon Oct 07, 2002 8:34 pm
O2 simulators New $80.00 (JACK)?
Venom VCN 1000 New in the bedroom $680.00 ( Currently spoken for)
M/T Street ET's 26/11.5X16 1/2 worn 170.00pr (SOLD)
M&H 28.5/10.5X15 1/4 worn drag slicks 160.00pr
stock y-pipe 15.00
98> front brake rotors used but not warped $50.00 pr
00>stock clutch plate & pressure plate 1/2 worn did not slip $50.00 can be used with 98> but requires flywheel
00 LS1 Flywheel $30.00
00 stock slave cylinder drilled out heavier pedal $20.00
Take off winter tires and 16in aluminum wheels like new $350.00 set of 4 (Chris)
Lower control arms competition enginering solid adj $125.00 pr. (Traded)
PostPosted: Tue Oct 08, 2002 8:49 am
I STILL WANT THOSE 02 SIMS!!!!!
PostPosted: Tue Oct 08, 2002 10:30 am
I´m interested! What kind of wheels?
Are the control arms or the bushings solid?
Will they fit my car?
(http://competitionengineering.com/catalog/CategoryDisplay.asp?CatCode=10004 <= these?)
PostPosted: Tue Oct 08, 2002 4:24 pm
Jack I can hold the O2 Sims for ya.
The LCA have solid adj eyes on both ends opposite threads and solid bushings.
PostPosted: Tue Oct 08, 2002 4:29 pm
They are 95 TA wheels with 16 winter tires.
PostPosted: Tue Oct 08, 2002 6:54 pm
Did you finally step up to a real y-pipe?? :p
PostPosted: Wed Oct 09, 2002 4:03 am
I have the SLP 21/2 for the last 2 years like the ground clearance.
PostPosted: Wed Oct 09, 2002 8:57 am
OH, ok I that's right. It just looks stock because it is such a thin pipe. :)
PostPosted: Fri Oct 11, 2002 7:53 pm
Mine is round not squished.
PostPosted: Fri Oct 11, 2002 8:14 pm
Oh, you must have changed it since that one time I saw it at Tony's, when we were comparing clearance!! :)
PostPosted: Fri Oct 11, 2002 8:17 pm
No no that was a 2 1/2 incher tucked in there, Stock is 2" an squiched on driver side.
PostPosted: Fri Oct 11, 2002 8:22 pm
I just thought I remembered yours being squished like my old one.. I think I'm gettin senile. Please excuse me. I say things sometimes without really knowing what I'm saying.
PostPosted: Sat Oct 12, 2002 9:59 pm
Well Jack you still want the 02 simms right.
PostPosted: Sat Oct 12, 2002 10:05 pm
For sure. Just wait 4 more weeks.. We should meet at Tony's or something.. I still have to settle up with him anyway.
PostPosted: Sat Oct 12, 2002 10:24 pm
sounds good I could bring a extra 100Hapees if your interested? J/K
PostPosted: Sat Oct 12, 2002 10:29 pm
LOL.. If I spend anything more than $500 now, it will be on those wheels.
PostPosted: Sun Oct 13, 2002 9:38 am
Are you including the tubes with these tires?
NovaRat
Size Does Matter!!!
PostPosted: Sun Oct 13, 2002 7:24 pm
It is better to run them tubeless they get hot and sticky quicker. Worked fime for me.
PostPosted: Mon Oct 14, 2002 5:38 am
OK. I'll take a look at them when we come visit this Saturday.
NovaRat
Size Does Matter!!!
PostPosted: Mon Oct 14, 2002 7:01 am
Sounds good.
