It is currently Mon Aug 24, 2026 1:10 pm
 Post subject: how to break into a fbody.........
PostPosted: Tue May 29, 2001 1:07 pm
well all you need is two car antennas, three zip ties an allen wrench and about two feet of speaker wire. oh and a little skill.
lash the two antennas together with two zip ties, then zip tie the allen wrench to one end and lash it securely to the antenna with the speaker wire. bend out the glass and slide the lock forward.
hah.....laugh it up ´cause that´s what it took this weekend to get my door open after i lock my keys in my car. i assure you from now on i will check twice before i jump out of my car in heavy traffic without the keys. most of the credit though must go to aaron, he´s the one that came to my rescue.
PostPosted: Tue May 29, 2001 1:16 pm
ouch!
PostPosted: Tue May 29, 2001 2:20 pm
lash the two antennas together with two zip ties, then zip [..]
Wanna try that on mine on the 16th? You're invited ...
PostPosted: Tue May 29, 2001 3:59 pm
Interesting, but I always leave mine in the ignition, until I know that I'm out, because it won't let you lock the car with the keys still in the ignition..
PostPosted: Tue May 29, 2001 7:30 pm
YOurs is no problem.... All you need is a razorblade, some clear tape and no skill... First you slice a hole in the top with the blade, reach in and unlock it with your hand. Once you are inside use the clear tape to reseal the hole..... I will bring my tools on the 16th..... LOL
PostPosted: Tue May 29, 2001 7:55 pm
Guess I'll make it a bit easier for you - I'll leave the roof down ... :-)
PostPosted: Wed May 30, 2001 4:55 am
No body has a sparekey. I guess that only works if you lock in the same city though.
Users browsing this forum: No registered users and 37 guests
