It is currently Sat Jun 27, 2026 4:03 am
 Post subject: finally did it...
PostPosted: Fri Jul 13, 2001 4:11 am
I finally installed the scanmaster in the air vent. Sure makes a differance when you can actually see the data this thing is reading.
PostPosted: Fri Jul 13, 2001 2:42 pm
Rob What does it do?
I am guessing it reads the cars vitals and puts that info into the digital display.
PostPosted: Fri Jul 13, 2001 5:39 pm
I was wondering/thinking the same thing!!
 Post subject: scanmaster details
PostPosted: Fri Jul 13, 2001 5:46 pm
Its a cool device, that basically allows you to see anything that the computer is monitoring, and it has the ability to record the highest/lowest O2 reading and timing retard during a WOT run (plus the mph that the reading was taken).
A full description is at: http://www.projecttransam.com/projects6.htm
Biggest benifits (beside O2 reading) is the ability to display current and stored trouble codes in your PCM.
Its a handy little device.
PostPosted: Fri Jul 13, 2001 8:47 pm
Sounds pretty cool!!
PostPosted: Sat Jul 14, 2001 5:55 am
You left out on important detail .
The Cost , Whats the cost?
PostPosted: Sat Jul 14, 2001 3:58 pm
If I remember correctly it was 229 or 249. And to answer your next question, it only works for 94-95 cars.
I think it was original made for the GN but somebody adapted it to OBDI LT1's
PostPosted: Sat Jul 14, 2001 6:02 pm
Dammit Lt1's get all the good stuff
