It is currently Tue Sep 29, 2026 7:13 am
 Post subject: a couple of pics from the races
PostPosted: Sat Jul 14, 2001 5:13 am
this is me all lonely in the middle in 1 billion degree temps (about 6:00pm). The other one is me and this guy (older, about 45-50) with his 99 auto 1le , its major power mod is a wet shot nos kit. He says he ran a 7.68 with 150hp jets and full slicks. If that is true, he was having a bad day, cuz pass for pass I killed him except on one where he beat me by .3 and 8mph. (He was using the 50hp jets)
PostPosted: Sat Jul 14, 2001 5:36 am
that reminds me of an old addage
"believe half of what you see and nothing of what you hear
when it come to racing.
Oh BTW GOOD win.
PostPosted: Sat Jul 14, 2001 4:01 pm
I will give him his props though, he was running on straight street tires, and I dont think he played with the adjustment on his konis either (1LE).
BTW we were by far the slowest two cars there, with the exception of a toyoto cellica and a eagle talon. ...By FAR the slowest.
PostPosted: Sat Jul 14, 2001 5:03 pm
Rob,
I'm glad you finally got to legitimately race, and beat, a LS1!! Good job. :)
 Post subject: thanks guys but...
PostPosted: Sat Jul 14, 2001 5:19 pm
I dont want to make this more than it was, because
1. I never lined up with him
2. I had DR to his street tires
3. It was a bad day, because of high humidity and temp that may have affected the LS1 more than me.
4. I varied which lane I ran, and he always ran the same one, so maybe that affected it.
His car was by far faster trap speed than me by between 5-8mph so if this was the 1/4 I probably would have seen tailights, but who knows. His best run with juice = around a 13.2, and my best run of 8.9 = around 13.7.
This is my friendly disclaimer so as to not start the inevitable engine/suspension/gearing battle posts that usually follow.
PostPosted: Sat Jul 14, 2001 7:55 pm
you can get him next time. Do your homework apply the facts and you will keep getten quicker. I smoked my clutch when I launched the way you discribed. But its stock
PostPosted: Sat Jul 14, 2001 10:09 pm
Who cares about all that, you beat him! That's what I'd say!!
PostPosted: Sun Jul 15, 2001 8:25 am
congrats, Is your car consistent?
PostPosted: Sun Jul 15, 2001 3:46 pm
The car tries to be as consistent as it can, but that damn driver is doing everything it can to screw it up!
I made 7 passes on this night, and the ranged from a 9.6 w/2.6 60' (1st pass, the tree caught me daydreaming) to a best of 8.9. the other 5 were all within 2tenths of the best with 60' between 2.1-2.2.
So I would say the car didnt drop off because of heat, or mechanically give up anything, but the driver just cant consistently launch the 6spd effectively enough to do brackets.
PostPosted: Sun Jul 15, 2001 5:21 pm
Find the G-spot this is the point where it does not bog and not to much tire spin, mine is 2500. 2200 bog-2700 tires smoke. Point is once you know the G-spot you can hook a manual choke cable to the throttle (hook it up to the normal accelerator by the firewall) right before you stage pull throttle cable to G-spot stage and launch the same every time, computer controlled cars are very unstable and it does not take much to miss the g-spot,all I do is sidestep the clutch stomp the throttle to launch it works pretty good and does not send you to the poor house.
