It is currently Thu Apr 16, 2026 4:17 am
 Post subject: More stuff...
PostPosted: Sun Sep 07, 2003 6:05 pm
I have some salad shooters (2) with some BFG Drag Radials mounted on. The tires have 1% tread left so I am unable to let you know how much life is still in them. B.O.
I have a cat back exhaust (stock) taken off of my 2000 Dakota Extended Cab truck. It only had a few thousand (if that) miles on it before I installed a Flowmaster. It's in one piece, pipe after the cat to the tip. B.O.
Auburn Gear limited slip diff- used, good condition
New never installed Torsen diff- not a take off. Missing the "paddle" :(
1990 VW Fox US specs, AC (still blows cold), 4-speed, silver 2 door. Aftermarket steel rims (common type found on older Golfs). Sorry, no bookshelf or fartcan exhaust. I can put some decals on it to make it faster for you though! :wink: Windshield cracked. (Autoglass has one for 120 eur.) Pay for the Kicker Speakers in the custom door panels, Kenwoods in the dash, and the Pioneer 6x9s in the back and get the car for free! Also has Audiovox cd player and Kenwood cd changer. Changer works when it wants to when it's cold.? Will include new timing belt, idler pulley, gasket set, Chilton's manual and fuel filter. (currently in trunk) Trunk lined with dynamat equivalant and carpet. (used to have system, might still have an amp or two available, subs are gone) Make me an offer. Car is parked on post in Giebelstadt.
PostPosted: Sun Sep 07, 2003 8:59 pm
Hey, give me an idea what you are asking for the car. I may be able to sell it. And if I do, it will get me out of replacing a fan, heater core, clutch, and everything else in an opel (for a friend).
PostPosted: Sun Sep 07, 2003 10:53 pm
SSZ28, I just got my car. I'll take whatever you're selling. I could really use those tires, and anything else for a 1996 Z28.
Thanks
PostPosted: Mon Sep 08, 2003 10:08 am
Wife says $400. It does need a little bit of work to pass inspection. It runs OK. It's parked in the end of the parking lot facing the "German" barracks. It has the "anti-Ford" emblem on the trunk.
PostPosted: Mon Sep 08, 2003 10:11 am
Thanks
Just give me a list of what you want, (of what I have listed) and a price. Like I said, the tread is now gone on the tires. If there is some way of checking to see how much rubber is still there without cutting the tire, let me know. I don't see any of the "wear holes" like found on some slicks.
PostPosted: Mon Sep 08, 2003 1:56 pm
Where is your list? I can't find it. Maybe its just the 2% rule, but I can't see it.
I could use a shifter, some drag tires, anything really.
Thanks
PostPosted: Mon Sep 08, 2003 9:53 pm
OOPS, it's not really a list, I tried to keep one part per topic so I can keep better track of who wants what. So far the shifter is spoken for, but if the deal doesn't go through, I'll let you know.
PostPosted: Mon Sep 08, 2003 9:57 pm
how much for the torsen diff?
1994 t/a
PostPosted: Mon Sep 08, 2003 10:17 pm
How about $80? It is missing the paddle thingy, but it wouldn't work if you have gears lower than 3.73. I think that these are the lowest that will still fit without needing a two-piece one.
PostPosted: Mon Sep 08, 2003 10:18 pm
342 will fit it right
1994 t/a
PostPosted: Mon Sep 08, 2003 10:38 pm
Yup. Any gear will work. It was just the missing "paddle" that interferes with the thicker gear or something.
PostPosted: Fri Sep 26, 2003 3:27 pm
Pics of rims and exhaust here: http://www.cardomain.com/member_pages/v ... 29&page=12
edit: Rims are currently "SOLD".
