Page 1 of 1
[ 16 posts ] |
395stang
Post subject: Wifey's Stang Posted: Sat Oct 11, 2003 5:57 am |
| Senior Member |
Joined: Tue Jul 03, 2001 10:05 pm Posts: 428 Location: N.C.
Well I got back to Bragg a little early . So I am building my wifes car now. Its a LX mustang with a 5.0 bored 30 over ( 306), forged internals, 10:1 compresion Eldebrock heads T, trick flow intake, 3:73 gears. B&M shift kit with 3000 stall converter,1.6 roller rockers, 70 mm throttle body, 73 mm mass air, 30 lbs injectors, Long tube headers,off road H pipe, msd ignition, custom cam. And soon a vortech with a small amount of boost( compression is to high for a lot of boost). And the real kick is that it is going to be pink with white flames. And some of you may get the chance to race her because we will be reenlisting to come back to germany. And if you were not beating me in my stang while I was there then you sure the hell wont be beating her.So if you have a pink Mustang pull up next to you and it is whistling I hope you are packing. And yes my wife can drive too. The only thing that worrys me is that she will beat me too. I am putting a T-trim in mine with 46 lbs injectors. I am running miid to high 11s with an a trim right now. I figure my wifes car will be running 11s when we are through. And I should be in the 10s with more boost.
_________________ many mods,
UAZ28SS
Post subject: Posted: Sat Oct 11, 2003 7:08 am |
Joined: Sun Sep 14, 2003 2:11 am Posts: 134 Location: Flagstaff, AZ... DoD jacked me over!
395stang
Post subject: Posted: Sat Oct 11, 2003 7:53 am |
| Senior Member |
I am especting no less than 425 at the wheels
nmonty
Post subject: Posted: Tue Oct 14, 2003 8:30 pm |
Joined: Sun Mar 16, 2003 11:30 pm Posts: 174 Location: Las Vegas, NV
When do you plan on being back in Germany? I'm trying to get my '91 GT into the 10's for next year. Could make for some fun in Bitburg if you get here in the next couple of years!! Good luck to you.
Garry
Post subject: Posted: Tue Oct 14, 2003 8:59 pm |
10's? Boy, you got some work to do there ...
JackZ28
Post subject: Posted: Wed Oct 15, 2003 8:09 am |
Yeah, that would be nice to see.... You're talking big bucks now... Good luck. I know it's very possible, but 10s don't come cheap.
395stang
Post subject: Posted: Wed Oct 15, 2003 4:26 pm |
| Senior Member |
Are you talking to me or monty? I know it takes a lot of money for a 3rd gen to be fast but I am just about there now. All I need is more boost and bigger injectors. As for my wifes car I think all she needs is 425 hp and that will be enough for her. I dont want her out running me.
JackZ28
Post subject: Posted: Wed Oct 15, 2003 4:28 pm |
395stang
Post subject: Posted: Wed Oct 15, 2003 4:42 pm |
| Senior Member |
I will be there by spring. We are going racing halloween night. They are haveing a freaky friday night. That is where they start racing at 5 in the evening till6 in the morning. I will try to get some picks of a 4th gen firebird doing a wheelie. And I will try to get some of my cars front coming up. I am trying to get my wifes car in the thirteens before I put her new motor in. It is still stock for now
sven
Post subject: Posted: Thu Oct 16, 2003 3:51 am |
Joined: Mon May 13, 2002 2:37 pm Posts: 612 Location: Renton, Washington, United States
it would be cool if she helps you
_________________ 1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
395stang
Post subject: Posted: Thu Oct 16, 2003 6:32 am |
| Senior Member |
She does help me. A couple of times I have been stumped and she will rattle somthing off I should check. And Ill be damned if it wasnt right. Makes me feel stupid some times
sven
Post subject: Posted: Fri Oct 17, 2003 3:47 am |
cool.......
SRZ
Post subject: Posted: Fri Oct 17, 2003 1:13 pm |
Did I read that right? You said you'll be back by this spring?! Talk about a quick turnaround. Hope you come back to K-town.
nmonty
Post subject: Posted: Fri Oct 17, 2003 7:31 pm |
I know i got a big job ahead, but i'm shooting for the spring right now. It might have to get delayed until mid summer, but only time will tell. I'm looking at a R302 block stroked to 347, heads, cam, and maybe supercharcher. But i think i want to do it NA, because it is just more fun that way. BTW, if anyone knows of any good engine builders in the states, i'm looking for one to build me a short block.
395stang
Post subject: Posted: Fri Oct 17, 2003 10:18 pm |
| Senior Member |
If you think you are going to do 11s natural asperated then you better have some compression and some good flowing heads. Those who know my car knows there is a lot of money and work in it and I am going high 11s. I dont know what you are driving but it takes more than motor to pull those tomes. Hawk will vouch for that. You need suspension and some type of slicks. I am putting more work in my suspension before I up my power. You can have all the power in the world but if it dont get to the ground then its a waste. I have gone 114 mph in the quarter and only had a 13.0 pass.Got the powr but wasnt getting the bite. Look at hawk 130 mph + passes but only 11sec slips. No traction that easily a 10( low 10 car). There is girl here running a 94 GT with a Vortech super charger and she is doing 10s She is not trapping much more than 120 but she has traction out the ass. She yanks the front wheels every time she launches. So if you want the time got to do the traction thing.
395stang
Post subject: Posted: Fri Oct 17, 2003 10:20 pm |
| Senior Member |
Silas I wont be there for at least 2005 but I wish next spring. The wife wants to go back too. I will be racing this sunday I will try to post some timeslips. I did a little tuning this week on the car. I will also post some times of the wifes car that is nearly stock.
Page 1 of 1
[ 16 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 42 guests |
