It is currently Mon Aug 24, 2026 2:42 am
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: wheels wheels wheels
PostPosted: Tue Jun 22, 2004 9:11 pm
Hey,
can I do this to my Z? :roll:
Front: 18x8,5, 32mm offset
Rear: 18x9,5, 32mm offset
PostPosted: Wed Jun 23, 2004 10:05 pm
if i read this one, then i see no probs, whatcha thinkin?
In order to determine the correct "offset" you need to be talking about a particular wheel width.
Offset is the distance the face of the mounting hub is displaced from the centerline of the wheel. Positive offset moves the inner edge of the wheel closer to the body, and reduces the amount the wheel/tire sticks out of the fender.
Backspace is the distance from the hub face to the extreme back outer edge of the rim and is equal to:
rim width/2 + offset + bead flange thickness.
The stock 16x8 wheels have a 55mm offset. That means that they have roughly a 6.65" backspace. If you take the "backspace" away from the total wheel width (nominal width + 2 flanges) you get "frontspace", or the amount the wheel sticks out from the face of the hub.
Stock: 16x8, 55mm offset, 6.62 backspace, 2.28 frontspace
WS6/SS: 17x9, 55mm offset, 7.12 backspace, 2.78 frontspace
I've run 9.5" wheels in the front, and the smallest offset I have run is 49mm. That made the backspace 7.14" and the frontspace 3.28". That put the outer edge of the wheel/tire just about where I wanted it. I believe the 17x9.5 Torque Thrust-II wheels for the F-Body have a 7.00" backspace and a 3.80 frontspace. To me, they are out a little toward the edge of the fender, but lets assume you could live with that.
In the rear, you can handle more "frontspace". My 17x11 50mm offset ZR1 replicas have a 7.93" backspace and a 4.00" frontspace. That is the max you can handle in the back.
Soooooooo....
For an 8" wide wheel - To keep a 3.80" frontspace, you need at least a 17mm offset. Any more than that, and you are outside the fenders.
For a 9" wide wheel - To keep a 3.80" frontspace, you need at least a 30mm offset.
For a 9.5" wide wheel - To keep a 3.80" frontspace, you need at least a 36mm offset.
All of this is APPROXIMATE, depending on the actual width of the flanges on the outer edge of the wheels that hold the tire beads on the rim.
PostPosted: Fri Jun 25, 2004 2:17 pm
these were the wheels ;)
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... 7905899875
PostPosted: Fri Jun 25, 2004 3:51 pm
You know that the bolt pattern of BMWs and F-Bodies isn't the same...?
PostPosted: Fri Jun 25, 2004 5:18 pm
yup...but it's almost the same *g*
there are many camaros/birds driving around with bmw wheels. or would you advise me against using them?
PostPosted: Fri Jun 25, 2004 5:31 pm
I know several people that do it. No problems. Heard on alleged story of the wheel falling off though. I have the BMW spacers and I had to have the holes bored out bigger to get them to fit. They still don't fit because they're not big enough. BUT that's spacers. BMW's wheels will mount right up no problem. Definetly have a bigger selection to choose from w/ their rims that's for sure.
PostPosted: Mon Jun 28, 2004 11:02 am
Well, I wouldn't do it. I'd be too scared that I COULD get problems with the wheels on the track. Of course I don't know how hard and where you drive your car...
PostPosted: Tue Jul 27, 2004 4:38 pm
Those sure would have been some nice ass wheels!
PostPosted: Tue Jul 27, 2004 5:12 pm
yeah man, but i thought they were too expensive considering the fact that they won't even fit 100% a camaro. but still, one wheel of those costs 900 EUR. whoever has them, has sure done a good deal...
PostPosted: Thu Jul 29, 2004 5:51 am
And a badass looking car! ;)
PostPosted: Thu Jul 29, 2004 8:41 am
if you like BMWs that yeah, hehe ;)
PostPosted: Thu Jul 29, 2004 12:06 pm
Well, from the wheel quality itself I don't think it would be a problem - if it's usable for an E46, it should take the speeds and torque of a Z ... so the question would be whether the spacer/adapter can take it ...
PostPosted: Wed Aug 04, 2004 12:45 pm
It would be fine. I had steel BMW 3 series wheels on my car with only minor spacing problems in the front. If I would have put my 1/4" spacers on, I would have had no problems. The rears were fine.
PostPosted: Wed Aug 04, 2004 1:33 pm
So what wheels are you getting or have?
PostPosted: Wed Aug 04, 2004 1:53 pm
He got the ones from Rob!
PostPosted: Wed Aug 04, 2004 2:22 pm
That lucky dog. What's he waiting on?! Slap them buggers on!
PostPosted: Wed Aug 04, 2004 2:25 pm
Just put them on, John! ;)
http://www.likeinheaven.com/camaro/wheelzzzzz/
PostPosted: Wed Aug 04, 2004 2:29 pm
Dude excellent choice! Don't sell those wheels no matter what. Classics and discontinued and very hard to find. Makes me want to pwd coat mine back to their orginal color. No I don't have those but I have the LG version exact rim minus the stud and forged instead of 3 piece.
PostPosted: Wed Aug 04, 2004 2:32 pm
Why all the doubts John. Yours look badass on your car- IN BLACK!
PostPosted: Wed Aug 04, 2004 2:34 pm
cool, the LGs are pretty nice and I thought about buying them coz I couln't find the Enkei Win anywhere. But then I found this pic http://www.mirons.de/bad_ass_red_z3.jpg and saw Rob's selling his so it was like destiny :D
