It is currently Tue Aug 25, 2026 1:15 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Fri Oct 22, 2004 5:01 am
Damn good weather and all ,and a meeting . Next time for sure.
PostPosted: Fri Oct 22, 2004 9:26 am
Yes it was great! :D
However, my rear brakes now make a scraping/squeeking sound. Pads look OK. The sound is ONLY when I drive forward and brake, it's absolutely quiet when braking backwards. Problem is I don't have a lift or something to really check it...
Can anybody help what this could be? Wanted to go to N'ring on Sunday. :cry:
PostPosted: Fri Oct 22, 2004 11:07 am
Ben ensure you check the inboard pad as well as the outboard pad. More than likely you need a set of pads. Won't know until you inspect it.
PostPosted: Fri Oct 22, 2004 11:19 am
Might be the anti-squeal shim too.
PostPosted: Fri Oct 22, 2004 11:22 am
Hmm you may be right... then I need new rear pads, guess that's not possible until Sunday... :cry:
Users browsing this forum: Bing [Bot] and 61 guests
