It is currently Sun May 03, 2026 3:37 am
 Post subject: Googleing people and friends
PostPosted: Sun Apr 17, 2005 5:19 pm
So do you Google people and Friends? You would be surprised at the amount of info that is out there ,to include addresses, news and photos. :shock:
PostPosted: Sun Apr 17, 2005 5:23 pm
Garry ,Stef and Silas and Jack your semi famous
PostPosted: Sun Apr 17, 2005 5:27 pm
don't try that on me unless you got too much time on your hands ...
PostPosted: Sun Apr 17, 2005 5:37 pm
Yeah,Garry your name came up all over the place .
PostPosted: Sun Apr 17, 2005 5:39 pm
Roy, its time to rethink things. I believe you shoudl get out and do some stuff. Like coming down here and helping me with my mods.
You by chance, have a pinion guage?
PostPosted: Sun Apr 17, 2005 5:41 pm
I have a machinist protractor which measures in degrees with bubble level . Will that suffice?
PostPosted: Sun Apr 17, 2005 5:48 pm
I don't know. You tell me. I have no clue what to set it at.
PostPosted: Sun Apr 17, 2005 6:01 pm
You better do some research.
PostPosted: Mon Apr 18, 2005 12:43 pm
Isn't a "protractor" a doctor that sticks his finger up your bum?
PostPosted: Mon Apr 18, 2005 3:58 pm
not to be cofused with a "proctoligist" who uses the "hubble telescope" :-eek:
PostPosted: Mon Apr 18, 2005 8:05 pm
Roy? Famous how? You using key words or something? I can't find myself and I'm sitting right here! LOL!
Daddy. -2 is max you want to set your pinion angle at for it to work both on the street and 1/4. Anything more and you'll be replacing parts. You'll be replacing parts soon enough anyways. LOL! I'd be wrong not to tell you. But you ever wonder why I don't use slicks? It's called the STREET TWIN! You will break either your drive shaft or gears. Matter of fact you're gonna break both on the 1st launch if you dump it @ 6K. It breaks the next weakest thing in the drive line. You should've researched before buying. :D
PostPosted: Mon Apr 18, 2005 8:57 pm
You told me that was the best way to go
PostPosted: Tue Apr 19, 2005 4:33 am
it is if you have a good d/s and 9in out back!!! I can understand a 4500-5000rpm dump but 6000rpms?????? I'm not even that rough on mine...DAM!! Silas is right .... the weakest link will be next. Knock on wood I've been able to get the weak links replaced before I broke them. Now I just need to learn how to drive it..............
PostPosted: Tue Apr 19, 2005 11:10 am
Yes I did. If going to build something build it right the 1st time. But you don't never ask questions. I ask around before I buy anything I don't stop at one person just because frick or frack says it's the way to go. I research the pro's and con's and what's safe etc.
You'll break it at 4K. Just so you know. Have money and tow at hand. :wink:
PostPosted: Tue Apr 19, 2005 1:49 pm
Hopfully it will hold up until I get back to the states
