It is currently Tue Aug 25, 2026 1:19 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 15, 2001 11:40 am
salveston get with me if you want to pump up your car. How fast do you want to go? $1500 will get you low 13s with what you got.
PostPosted: Sat Sep 15, 2001 9:01 pm
An E-7 in Illershiem, he has a 97 (I think) Z28 with a boken con rod. He is suppost to be picking it up this weekend.
PostPosted: Mon Sep 17, 2001 5:40 am
Well he decided not to get it. The engine is now available again. Hey Jaz, does your friend need a engine??
PostPosted: Mon Sep 17, 2001 9:58 am
 ICQ  YIM  Profile
Randy... You help me blow my engine and I'll buy it. I need to not f up the tranny right? You got that 6 speed off of that right? I will have that extra $100 coming from Bruce, anyway. But I haven't even driven my car since Tuesday night, can't get off post. I go and sit in it and start her everyday though. I wanna drive!
RT1
PostPosted: Mon Sep 17, 2001 6:55 pm
Sounds good can I come down this weekend to check it out I need to talk to tony about what adapters we will need. Give me your # so we can hook up. JAZ
PostPosted: Mon Sep 17, 2001 9:28 pm
RT1, in order to make it all work you need much more than the engine itself.
Since it was a 6 speed you need either a new PCM or severe reprogramming, also a new wiring harness is needed plus all the other goodies like the good ol' Crossmember to start with, radiator, dual fans, hoses, fuel lines, powersteering resevoir, etc etc. Also do keep in mind that your 40L60E does not bolt on to the Lt-1 just like that, a new belhousing is needed.
Believe me, i've done the math and know exactly what's needed.
Sergio
PostPosted: Tue Sep 18, 2001 12:44 pm
 ICQ  YIM  Profile
So you are saying that I could keep the same gas tank, and the body, right? Thanks, I am glad you have done your homework on this. You rock dude.
RT1
PostPosted: Tue Sep 18, 2001 2:47 pm
on most of your hoses you cut and adapt them to fit..nad the radiator will or should work off a thirdgen tpi along with the fuel pump... have any more ? go to thirdgen.org and go to motor swap section
PostPosted: Tue Sep 18, 2001 9:28 pm
Jaz, or anyone, A German guy just waved the cash in front of me today and wants it now. If any of you are serious about this motor you must get back to me ASAP. I would rather help out FBE, since you are my people's!! Otherwise consider this engine gone.
PostPosted: Thu Sep 20, 2001 8:16 pm
The engine has been sold.
PostPosted: Thu Sep 20, 2001 9:28 pm
I'm glad you finally sold it Randy!! ;)
PostPosted: Tue Sep 25, 2001 2:38 pm
Geez about time man!
