It is currently Tue Mar 03, 2026 12:18 pm
 Post subject: Bitburg again?
PostPosted: Thu Sep 22, 2005 12:56 am
Who is going to be there there the 1/2 October? Unless something comes up I will be there this time.
PostPosted: Thu Sep 22, 2005 8:24 am
yup. I'm there.
I hope.
2011 Chevy Camaro SS/RS
Sold my Bird to ChrisV6!
1998 Skyline GTS - SOLD!
PostPosted: Thu Sep 22, 2005 9:03 am
Cool, maybe I can speak at ya about some car audio. :) Looking for a decent 5 channel amp.
PostPosted: Fri Sep 23, 2005 8:13 am
yeah hopefully Jaz will apear this time too
why do you need 5 channels?
PostPosted: Fri Sep 23, 2005 2:28 pm
I want to run all my speakers of one amp instead of two. Call me weird but I dont want a seperate amp for the sub. I am not going for any competitions I just want a good clean powerfull sound.
PostPosted: Fri Sep 23, 2005 4:10 pm
ok. will you have (2) sets of components? Fronts and Rears?
What type of Sub are you wanting to go with?
if the amp is powerful enough, you might only need a 4 channel..but I dont recommend running the sub on the same amp, because usually you will bridge the Sub output and it will task the amp the most. Bass hits and surges, with a Vmax peak. This will task the amp too much and cause alot of heat.
Usually you can run your component sets off the deck, if its high powered enough (usually will be if you by component sets with a X-over box, so the deck will only basically have to power the tweets for highs and the cone woffer for mids)
Then you only need a 2 channel amp, bridged for the sub.
If I'm wrong, Jaz will chime in.
PostPosted: Fri Sep 23, 2005 8:15 pm
I'm getting CDT ES 620-Z and 600 with a NINE.2.
All I need is a mono amp that puts out 450W RMS for my PG Sub....
And of course I need to install this stuff.
PostPosted: Fri Sep 23, 2005 8:19 pm
I already have everything minus the sub and amp. I have a Sony deck with Polk Audio 6.5 components and just regular Polk Audio 6.5's. I just need the sub for the lows. I think the deck does not supply enough power to speakers to get them to sound nice. I may be off but that is my take on it. It’s not the most high-end deck in the world. I just like the idea of a 5 channel amp, keep it simple. When you driving at 140+MPH it does not really matter what your system sounds like. :shock:
PostPosted: Thu Sep 29, 2005 10:26 am
Come on, others have to be going this weekend?
PostPosted: Thu Sep 29, 2005 11:56 am
yea there is others going but we are talking about it in the say what ever forum. under the test of driving skill or something like that.
