It is currently Tue Aug 25, 2026 4:54 pm
 Post subject: New "new Camaro 2009" pictures
PostPosted: Thu Dec 08, 2005 12:34 pm
Look here:
http://community.webshots.com/album/518973697aeGssB
PostPosted: Thu Dec 08, 2005 1:50 pm
I think Gm missed the mark with that setup. :shock:
PostPosted: Thu Dec 08, 2005 2:05 pm
It's ugly...
PostPosted: Thu Dec 08, 2005 2:16 pm
Can someone post a pic for me??? Its blocked down here.
Thanks
PostPosted: Thu Dec 08, 2005 3:27 pm
it's got potential, but needs a lot of work.
PostPosted: Thu Dec 08, 2005 4:28 pm
Thanks
PostPosted: Thu Dec 08, 2005 5:30 pm
1st of all, it's a concept design and only out of the computer ...
Then, do I understand that one chassis design pic correctly that they plan on finally not putting a stiff rear axle in? :)
Design looks like they used junked Ford-designs as a base ;)
Oh well, if they use this as a concept, it won't look anything like it anyway ...
PostPosted: Thu Dec 08, 2005 5:44 pm
I too believe the outside has potential. On the other hand, that interior is awful!
PostPosted: Thu Dec 08, 2005 7:55 pm
When you squint at the front view, it certainly looks as if there's a pony on the grille badge (instead of a bowtie).
That's not a computer model, it's a real clay mockup with a Dynoc skin over it. You can see that the model is assymetrical (that way you can cheaply evaluate 2 designs against each other) and it is standing on jackstands on an outside turnstile (so that you can rotate the model and evaluate it from a distance). It is still early stages when you go thru that process. When you get closer to reality then things like that slinky outside mirror will turn into something big & ugly. If the car is slated for 2009 then I am not so sure that the nose (as shown there) will comply with the 2010 "lower leg impact law, stage 2".
That chassis plan certainly has an IRS rear suspension.
The dash is plainly awful. usually when you have no creative design then you hit that retro sh*t.
PostPosted: Thu Dec 08, 2005 8:59 pm
The low roof doesn't look too bad IMHO ...
PostPosted: Thu Jan 05, 2006 9:40 pm
i like this one better then that red 1st gen look-alike whatever concept :D
PostPosted: Fri Jan 06, 2006 1:58 pm
Its gonna be to see live at NAIAS in a couple of days if I got it right... can't wait to see it!!!
PostPosted: Sat Jan 07, 2006 5:50 am
The concept car will be unveiled at the Detroit Auto Show on Monday the 9th. It is being shown to a select group of Camaro enthusiasts on the 8th with a promise from each of them not to distribute any pictures. This is straight from a GM executive.
