It is currently Mon Apr 27, 2026 11:53 pm
 Post subject: Need 98-02 rear end (3.42)
PostPosted: Fri Mar 03, 2006 6:38 pm
Hi,
I'm looking for a rear end for my 98 Trans Am.
I need a 3.42 ratio.
It can be an original GM 10 bolts or even better a 12 bolts or a 9"
Thanks - Stefano
PostPosted: Sat Mar 04, 2006 10:36 am
What is your price range?
PostPosted: Sat Mar 04, 2006 11:36 pm
well, I can have an occasion Zexel Torsen series 3 carrier + GM gears + rebuild kit for $450 (I then have to rebuild mine).
In the states a guy would sell me his 11'000 miles rear end for $400...
I would say the price should be between $400 and $500, but you can tell me what you have and your price.
I already rebuilt mine once but either the parts weren't good or I made a mistake. The internal poinion bearing is damages and the gears are now damaged too and are noisy.
It should be a low mileage rear end with original GM parts with two sensors for ABS and traction (no central reluctor ring).
Even better would be a 12 bolts or 9", but then it's clear that the price changes...
I live in Switzerland: it's not a problem for me to organize a shipping company to pick up stuff in Germany (or worldwide).
Thanks - Stefano
1998 convertible Trans Am
MODS: A4 > M6 conversion, SC raptor hood, Vortech V9 G-Trim SQ, homemade water-alcohol injection, Strano sway bars, Koni SA shocks
DYNO: 410 RWHP, 417 RWTQ @ 5 PSI
PostPosted: Fri Mar 10, 2006 5:06 pm
I have one!
:D :D :D
