It is currently Sun Jun 14, 2026 8:03 am
 Post subject: 2000+ fuel tank?
PostPosted: Sat Jun 24, 2006 2:06 pm
still need to figure out details, but just in case - does anybody happen to have a fuel tank flying around that will fit a 2000 F-Body?
PostPosted: Sat Jun 24, 2006 2:24 pm
I had one, was it in the black camaro's trunk? ...still in there when S!mon took it, then. Got to ask him, I am sure he does not need two.
What happened?
PostPosted: Sat Jun 24, 2006 2:27 pm
'hawk seems to have a small leak somewhere on top - only noticed since it was completely filled ... (which I did after coming home from Bitburg)
Guess will have to drop the rear end some time soon and see where it's coming from ...
Why was there a 4th gen fuel tank in the trunk of the black 3rd gen?
PostPosted: Sat Jun 24, 2006 3:35 pm
i have a tank from a 1999 camaro 3,8 V6. Don´t know, if this one will fit
PostPosted: Sat Jun 24, 2006 3:53 pm
Hm ... I'll check the parts manual and see if there are different part# listed ...
Edit: 99-02 Camaro seems to be the same, no different versions listed ... now if I knew whether the Firebird uses the same tank as the Camaro ... *gg*
Anyway, 02 lists another fuel tank with "L36" ...
PostPosted: Sat Jun 24, 2006 5:05 pm
don't know if it was a 3rd or 4th gen, but it seemed not to be very old, and since I don't know where it came from...
PostPosted: Mon Jun 26, 2006 9:38 am
The 99 fuel tank should fit. The camaro and Firebird are the same. The tank is made of plastic.
@ Garry,
It is probably just one of the many plastic hoses on top of the tank leaking. It is a pain to get the tank out but it is way easier than the old metal tank. Good luck.
 Post subject: Re: 2000+ fuel tank?
PostPosted: Sat Mar 15, 2008 11:38 am
Well, finally took a look at the tank ... looks like one of the heat shield started rusting through, and the exhaust started melting the fuel tank :shock:
So, a replacement it will have to be ...
Anybody happen to have a spare, or know of a car to part out?
PostPosted: Sun Mar 16, 2008 6:51 am
Hey garry i got a 2001 trans am ws6 fuel tank still here. With fuel pump (plastic tank version of course). You still need it?
PostPosted: Mon Mar 17, 2008 12:08 pm
i still have the fuel tank
PostPosted: Tue Mar 18, 2008 9:12 am
Thanks Jens, Ben's dad is dropping of the other tank at the shop today ... (Thanks Ben & his dad!)
PostPosted: Tue Mar 18, 2008 8:42 pm
No problem Garry glad we could help ya out with the gas tank. Now you can go out and smoke those 911's again because you can fill up(but not with the gas price). Heard you putting new cam and heads on the motor. HMMMM watch out M5 Garrys comen by.
PostPosted: Tue Mar 18, 2008 10:26 pm
Goal is 12.99 or better for the Pro E/T Series ... dunno if I can make it on street tires though ... well, I'll see ...
PostPosted: Wed Mar 19, 2008 5:57 am
just a a sub box to get it to hoock. (J/K)
PostPosted: Wed Mar 19, 2008 6:17 am
Street drags would be a possibility, but I don't think the 10bolt can really take it ... hope I don't tear up the rear with what the motor will be dishing out ...
PostPosted: Sat Apr 19, 2008 8:14 am
I'd start saving for a rear end now. It's just a matter of time.
PostPosted: Sat Apr 19, 2008 9:32 pm
Thanks a lot ;)
Nah, I guess as long as I stick to street tires, I shouldn't be in too much of a problem ... oh well, and if it does break, Ford it is ... ;)
