It is currently Sat May 02, 2026 6:31 pm
 Post subject: D@mn Battery ...
PostPosted: Tue Aug 08, 2006 6:56 pm
I know the alarm system drains my battery, but over the last three weeks, it really did it in - 'vert was dead, recharged it for a while, tried to start it again, went dead again - only that when it did, now the charger blew its fuse due to too many amps pulled by the battery ... guess I need to find a new one if I don't want to switch the battery between the 'hawk and the 'maro ....
PostPosted: Tue Aug 08, 2006 7:56 pm
I remember somebody disconnected the Battery to give it a chance to recover enough to start, then when re-connected the Alarmsystem started to talk, draining the Battery before there was a chance to restart the car...
Take that unneccessary stuff off.
PostPosted: Wed Aug 09, 2006 7:29 am
Optima Reds are the best. My Jeep came with it from the factory.
PostPosted: Wed Aug 09, 2006 7:34 am
... need to check with some places here, those "US-Style" batteries are hard to get ... most/all german/european cars come with the other style connectors ...
PostPosted: Wed Aug 09, 2006 10:51 am
Ebay has them...
Look here, located in Bitburg:
http://stores.ebay.de/Hermann-GmbH
PostPosted: Wed Aug 09, 2006 10:59 am
My last red top was $109 and the last Yellow top was $149
PostPosted: Wed Aug 09, 2006 1:40 pm
Am I blind? All I see there are batteries that would fit any german/import brand car, but not the "screw-in" type connections as we need for an F-Body ... !?
PostPosted: Wed Aug 09, 2006 2:04 pm
if you're looking at Optimas, they have both top and side post on them with covers for which ever ones you don't use.
PostPosted: Wed Aug 09, 2006 2:32 pm
http://www.optimabatteries.com/publish/ ... plash.html
http://www.optimabatteries.com/publish/ ... otive.html
PostPosted: Wed Aug 09, 2006 5:14 pm
Found new gel battery turned in at our Battery shed again... but only for the Forces to be issued to, if no unit comes to get it, I will have to send to recycling with the several hundred thousend tons yearly.... :?
Why can't all those mechanics order the right size in the beginning?
We get a lot of that stuff from downrange and actually we're not supposed to take Haz Mat any more... but impossible for us to send it back. :roll:
