It is currently Mon Aug 24, 2026 10:29 am
 Post subject: Came up short once again for the 10's with video
PostPosted: Wed Sep 13, 2006 9:42 am
I had a pretty frustrating weekend at Bitburg. Finally the track was biting hard and I ran into problems. I still have not gotten a full nitrous pass out of this car. It is unfortunate that I did not find out what the problem was until it was too late. I ended up hurting the motor on my final pass. I ran 11.13, 11.15, 11.03, 11.04, 11.29, and 11.51. The problem was that I had two fuel jets on the kit that were clogged. It is the downside to running a direct port kit with high fuel pressure. The fuel jets are .012". You can barely see through them. It only takes a tiny piece of dirt to clog them. I am going to tear it down tonight to see what it hurt. If I can fix it, then I will bring it to the Oct Bitburg and try again. This time it will be with the 200hp jets. That way I can run a little bigger fuel jet in it and avoid clogging it. It was good seeing some of you at the track this past weekend. I wanted to make a pass a stop at the auto X but I decided not to run it at all on Sunday. See ya'll in October!
Here is a video of the pass that hurt the motor.
http://www.fbodyeurope.org/albums/Bitburg-Drags-Sep-06/NX_Z28_VIDEO.avi
PostPosted: Wed Sep 13, 2006 9:48 am
Don I hope its nothing too serious.
See ya in October
PostPosted: Wed Sep 13, 2006 9:58 am
11.03 is still one hell of a run. Best of luck for next month
PostPosted: Wed Sep 13, 2006 10:14 am
Thanks. I just hope I did not melt the block.
PostPosted: Wed Sep 13, 2006 12:48 pm
Well,
I did a compression test on the motor at lunch. 0 psi in cylinder #6. The rest of the cylinders were fine. Now I have to pull the head on that side :(
PostPosted: Wed Sep 13, 2006 1:35 pm
Damn man that sucks I know the feeling. Hope it aint the piston or the ring's.
PostPosted: Wed Sep 13, 2006 1:40 pm
Don't care if it is the piston or rings. I have brand new Diamond rings in my room and I can order my pistons individually. I just hope it did not hurt the block and mess up the head too bad. Lucky I did not sell you those head gaskets. :lol:
PostPosted: Wed Sep 13, 2006 1:44 pm
You have head studs right? That might make it a pain the ars but mine was easy to take apart.
PostPosted: Wed Sep 13, 2006 1:49 pm
I'll just take them out like a head bolt and then pull the head off. If that is too much of a pain, then out with the motor.
PostPosted: Wed Sep 13, 2006 2:08 pm
Good luck ... hope it's just something minor ... is that one of the cylinders that had the clogged up injector?
PostPosted: Thu Sep 14, 2006 8:21 am
Got it apart last night. It burned two tiny slots in the exhaust valve on the #6 cylinder. No damage to the piston, rings, block, or sleeve. :lol: I have to order another valve from Patriot and it should be back up.
PostPosted: Thu Sep 14, 2006 8:39 am
Phew ... glad to hear ... so, good chances to be running within the next 4 weeks & in time for the October finals :) :ok:
PostPosted: Thu Sep 14, 2006 8:52 am
Will be there Garry. I am planning on running a bigger shot in the system.
PostPosted: Thu Sep 14, 2006 9:59 am
I am planning on being there also I am ordering everything monday. just going to be waiting on parts.
PostPosted: Thu Sep 14, 2006 10:40 am
Sounds good ... we need more F-Bodies there to take on the Mustangs and the German/Import trash :)
PostPosted: Thu Sep 14, 2006 8:27 pm
Don's Video 11:038
http://www.youtube.com/watch?v=yCq6ZjbhhCs
PostPosted: Fri Sep 15, 2006 4:19 am
Glad to hear she is ok and nothing huge happened.
Im still struggling with traction problems and being scared of shifting the POS hard (running a POS T-3550). Launching at just about idle it 12.1s @ 119 MPH on motor (2.1s 60fts times) and an even slower 12.3s @ 126.71 MPH on the juice….launching at idle, no traction what so ever: spining hard in 1st, 2nd and a bit of 3rd. I had to lift in 1st and 2nd gears. I feel that on a “fullâ€
Garden Snake
PostPosted: Fri Sep 15, 2006 7:49 am
@ Naz,
That is a nice trap speed on motor and spray. I can never get mine to run out. What is your trap in the 1/8th mile? That is where mine starts laying down. Slow5.0 took pics of the valve. I think he is going to post them today or tomorrow. Now get a cage!
PostPosted: Fri Sep 15, 2006 10:22 am
TurboManiacal wrote:
Thanks for posting but I cannot watch it at work. :cry:
PostPosted: Fri Sep 15, 2006 10:42 am
Bruce is going to cry. :P
Users browsing this forum: No registered users and 46 guests
