It is currently Wed Nov 05, 2025 5:51 am
 Post subject: I GOT MY PART'S IN!
PostPosted: Thu Oct 26, 2006 11:47 am
So my car will be running this weekend, then in the spring I will take it all apart and put the heads, cam and whatever else I aquire between now and then on.
PostPosted: Thu Oct 26, 2006 12:22 pm
Good to hear the progress! Hurry up and enjoy the weather before it changes.
PostPosted: Thu Oct 26, 2006 1:55 pm
Finally ... hope the weather holds up a bit so you can still enjoy it :)
PostPosted: Thu Oct 26, 2006 6:32 pm
What took so long ?
PostPosted: Fri Oct 27, 2006 6:15 am
I'm with Roy on this. Who did you order them through? Texas Speed.
PostPosted: Fri Oct 27, 2006 7:31 am
I ordered them through thunder racing it only took 3 week's to get hear I wish I would have went ahead and got arp head studs I got arp head bolts. I got the MLS gaskets also.
PostPosted: Fri Oct 27, 2006 10:22 am
The reason I asked
Is that My head gaskets head bolts and rod bolts were here in 5 days for m the time of order.
PostPosted: Fri Oct 27, 2006 10:43 am
Who did you order them from?
PostPosted: Fri Oct 27, 2006 10:50 am
Thunder Racing is an excellent company and they offer military discounts. The only problem is that they only ship on Fridays. So if you order on Monday, you lose 4 days waiting on them to ship.
PostPosted: Fri Oct 27, 2006 4:19 pm
scoggins dickey
PostPosted: Wed Nov 01, 2006 7:05 am
Well I have an update ,,, one of the damn bolt's broke in the block so I called arp and they are sending me a new one for free but I don’t know how the hell I am going to get the remainder of the bolt out. Any ideas?
PostPosted: Wed Nov 01, 2006 7:20 am
Can you post a pic of it? I hope that it did not have any water in the bolt hole. I have never heard of an ARP bolt breaking.
PostPosted: Wed Nov 01, 2006 7:23 am
No water I cleaned them all out twice before I started on it.
PostPosted: Wed Nov 01, 2006 7:38 am
I think there are special reverse screws made to take out broken screws ... think you have to drill a hole, then screw in that piece turning it left ... hope it's not stuck too hard ...
PostPosted: Wed Nov 01, 2006 11:08 am
I will see if the Germans around hear have some I can buy. Also I looked on ls1tech and there were some people on there that have had the same problem as I did. I should have went with the studs. :cry:
PostPosted: Wed Nov 01, 2006 12:08 pm
The tool your looking for is called an"easy out", the local craftshop should have some. Drill in the center of the broken bolt and then screw it in and it'll back the bolt out. Had an intake bolt break and had to do it, really easy took 15mins.
