Page 1 of 1
[ 12 posts ] |
RT1
Post subject: Help! Posted: Wed Sep 26, 2001 9:46 am |
Joined: Mon May 28, 2001 7:46 pm Posts: 1091 Location: El Paso, TX
RT1 is sick... Will crank, won't start. Checked the fuses... checked the fuel pump... tried to jump...
I am about to call ADAC
RT1
Hawk
Post subject: Posted: Wed Sep 26, 2001 11:47 am |
More details did you check the simple stuff/ How long was she setting.
RT1
Post subject: Posted: Wed Sep 26, 2001 2:21 pm |
Details, ok, lets see... Just had a amp and some speakers put in on Mon, That's why I went straight for the jump. She was sitting over night. Haven't checked to see if the plug wire will arc to the plug yet, the wife isn't home until 6. What else you need to know?
RT1
Hawk
Post subject: Posted: Wed Sep 26, 2001 2:24 pm |
Sounds like a short. If you hooked the amp to the ignition wire? If you go for a jump and that is the case you could do some damage. I would unhook it and go from there.
RT1
Post subject: Posted: Wed Sep 26, 2001 2:29 pm |
It was none at an audio shop... So I was thinking they knew what the were doing. What would be some of those symptoms of a short like that? i.e. would the radio still work? would it be doing what it is doing now? or would it blow a fuse?
RT1
Hawk
Post subject: Posted: Wed Sep 26, 2001 5:19 pm |
Take it back to the audio shop and have them fix it.
RT1
Post subject: Posted: Wed Sep 26, 2001 6:03 pm |
So you are saying that it is the new stuff? Would I still be able to play the stereo, if it was shorted? It seems that everything else is working, including the stereo. I would take it back, but it won't start. I will call them in the morning. Thanks for your help, I gotta get it running for the $100. That is the funny thing though, I went out to the car to take a picture of your car in the rearview mirror. I cut your car out of one of the flyers, and put it in the rearview... see where $h!t talking gets me.
RT1
RT1
Post subject: Posted: Fri Sep 28, 2001 2:43 pm |
Bruce... got some other stuff to run by you. It has a hissing sound at the engine, when the fuel pump is engaged. And I disconnected the amp and stuff... still the same thing though. I just got one of our other hoopties through inspection so I can concentrate on my baby now.
RT1
JazWhelan
Post subject: Posted: Fri Sep 28, 2001 10:19 pm |
Joined: Wed Jul 18, 2001 7:02 pm Posts: 168 Location: Spangdahlem GE
The stereo install if done right should have nothing to do with your car starting -- besides a drained battery...
Dark Angel
Post subject: Posted: Fri Sep 28, 2001 10:41 pm |
Joined: Sun Aug 26, 2001 4:51 pm Posts: 681 Location: RAF Lakenheath, UK
But a stereo install done right shouldn't have alternator whine either.
_________________ Dark Angel is ready to rumble!!!!
RT1
Post subject: Posted: Sat Sep 29, 2001 10:20 am |
Thanks, I am completely stumpted on this one. It isn't the alternator making the noise, sounds like at the top of the engine. Could it be the fuel system pressurizing? Or is it sucking air? F*#^ if I know. I am about to tow her down to the Opel. Thanks for all the help though guys, I do appreciate it.
RT1
RT1
Post subject: Posted: Sat Oct 27, 2001 6:27 pm |
This just in... The Crank Sensor was f##kered. I didn't even know that it would shut the ingition down, if there wasn't a signal. Good thing I took it to Opel, AAFES prolly would have never seen that one. Thanks for all the advice.
RT1
Page 1 of 1
[ 12 posts ] |
Users browsing this forum: No registered users and 32 guests |
