It is currently Wed Sep 09, 2026 12:24 pm
 Post subject: ls2 flywheel
PostPosted: Mon Dec 04, 2006 4:50 pm
like the title said:
looking for used ls2 flywheel in good shape. :)
thanks, JeeJee
PostPosted: Fri Dec 08, 2006 9:00 am
Isn't the LS1 flywheel the same? Not too many people have an LS2 over here. I have only seen one.
PostPosted: Fri Dec 08, 2006 12:13 pm
no it's not the same, you can use both (ls2 flywheel on ls1 and ls1 flywheel on ls2)
the ls2 has more a "bowl" flywheel where the plate is "inside" the flywheel.
jeejee
