It is currently Tue Aug 25, 2026 10:07 am
 Post subject: Well Iwent and bought a Ford today.
PostPosted: Thu Mar 08, 2007 6:46 pm
Yep
I broke down and bought A Ford today . The price was right and I always wanted a Ford Sierra Cosworth RS 4X4. It needs a little work Like a engine cradle , right front propshaft.
Itseems to hve been uned to by a company called SUHE . The Fahrzeug says max ladedruck is 1.4 bar.
This probaly why the propshaft broke whhich in turn broke the engine cradle.
Here is a engine shot of it
PostPosted: Thu Mar 08, 2007 7:17 pm
is this the one that was by the craft shop on landstuhl?
PostPosted: Thu Mar 08, 2007 7:21 pm
Bingo , Were you interested in it too?
PostPosted: Thu Mar 08, 2007 8:47 pm
Right, now the fun starts. Those engines respond very well to a set of bigger injectors, bigger turbo, bigger intercooler and a chip to regulate everything. You will be surprised how much potential is still available. And don't forget to remove the overrun cutout from the programming, that way you can spit 6foot flames every time you lift the throttle.
PostPosted: Thu Mar 08, 2007 8:53 pm
Stef
It looks like this company called SUHE did a SUHE 293 upgrade to it . All Tuev approved and all. But I am a little leary of that Turbo pumping out 1.4 Bar .
I am currently looking for an engine Cradle for the 4X4 variant. The one that is on there is cracked. Got any leads ? Any one?
PostPosted: Thu Mar 08, 2007 9:21 pm
Did you ask Jochen?
PostPosted: Thu Mar 08, 2007 9:24 pm
I was actually tryin to get it for him but I decided to keep it because it not in that bad shape .
PostPosted: Thu Mar 08, 2007 9:49 pm
no, but I was there the day he broke it....remember the huge speed bump going out of Landstuhl?...well he took it at 30 MPH, or K's one or the other
PostPosted: Thu Mar 08, 2007 10:46 pm
I pumped my "ex" Nissan to 1.4 Bar. The thing went like a scalded cat until it threw a rod at max revs. Destroyed everything!
Cossies are made of better stuff though.
PostPosted: Thu Mar 08, 2007 11:09 pm
Roy, you will love the way this car drives compared to the camaro
(not that there is anything wrong with that one)
Cossies are nice stuff, the crank and rods are forged steel and pistons forged allso.
standard there is allso a piston cooling oil spay
What kind of headgasket does it have ?
multilayer ?
the normal ones tend to let go around 300HP
try to get hold of a T35 from a ascort cosworth, as the T3's even from a 4x4 run out of steam at a little over 300HP.
these buggers kill driveshafts... especially with the boost turned up :?
PostPosted: Fri Mar 09, 2007 9:19 am
A good friend here in Wiesbaden has a Suhe tuned Sierra, 430hp worth. he was a master mechanic for Ford but now owns several gas stations in the area. I will stop by and see if I can find out what parts he has around. His Sierra is in great shape and is not afraid to drive it.
PostPosted: Fri Mar 09, 2007 9:29 am
http://www.autoscout24.de/home/index/de ... etail_bild
Has no head on it. Just FYI
PostPosted: Fri Mar 09, 2007 10:07 am
Blasphemy!
J/K!
PostPosted: Fri Mar 09, 2007 11:37 am
So is this going to be your new race car?
PostPosted: Fri Mar 09, 2007 11:51 am
i hope not :wink:
PostPosted: Fri Mar 09, 2007 12:12 pm
If I can't find a engine cradle or subframe , the car won't be doing much of nothing except sitting.
PostPosted: Fri Mar 09, 2007 6:41 pm
That means I'm going to see you this Sunday at Hockenheimring with your Camaro. :wink:
PostPosted: Fri Mar 09, 2007 6:43 pm
That is if it stops raining and I get my kitchen pass approved.
PostPosted: Fri Mar 09, 2007 6:52 pm
:ok:
PostPosted: Fri Mar 09, 2007 9:43 pm
Users browsing this forum: No registered users and 37 guests
