a10beav
Post subject: failed inspection Posted: Mon May 14, 2007 4:05 pm |
I need a new tie rod end, but I'll order that tonight.
I need an on/off switch for the foglights; where are auto parts stores in K-town?
The exhaust is too loud, 101db. I had some steel wool in the exhaust, but I don't think I can cram enough in there to pass inspection. I've been looking at bullet mufflers, but Dynomax only advertises a 2-4db change and the other brands seem too large. I already have low exhaust in the front and I don't want more problems. I'm debating a new muffler because of that.
Gary, do you still have the stock exhaust on the Hawk?
And finally, I need to remove the front window tint.
Oh well, I guess it could have been worse...
Garry
Post subject: Posted: Mon May 14, 2007 4:59 pm |
Yes, stock Firehawk that is ...
mpsolo
Post subject: too loud Posted: Mon May 14, 2007 5:30 pm |
Joined: Wed May 11, 2005 8:04 pm Posts: 33 Location: Darmstadt, Germany
Man I failed with 103 db so I stuffed a bag of steel wool in each pipe and it got so quiet I didn't get a db test the second time. Good luck!!!
a10beav
Post subject: Posted: Mon May 14, 2007 5:45 pm |
I emailed a few companies and Moroso says I could see about around a 7db decrease. It doesn't look too restricitive either.
I don't see how you can fit a whole bag in each pipe, seems like it would blow right out!
jinstall
Post subject: Posted: Mon May 14, 2007 7:14 pm |
Joined: Tue Jul 12, 2005 5:08 pm Posts: 942 Location: Fort Bliss, Texas
The More the better, it does the trick. I use Supetrapp so I can adjust the sound witht he disc as needed.
_________________ 2001 Ford Focus sleeping in Germany 04 Focus ST170 Clone in USA 2010 Renault Clio 1.2 16V in Germany 2013 Focus ST250 in the USA 1st car 77 Camaro Type Lt 5.0 auto
Post subject: Posted: Mon May 14, 2007 7:38 pm |
Yes the steel wool works . But you want the wool in there as loose as possible with out it blowing out . also be gentle on the gas pedal .
a10beav
Post subject: Posted: Mon May 14, 2007 8:12 pm |
I was pretty gentle on the pedal, but the inspector jumped in the seat and blipped the throttle a few times before running it up. I crammed some wire mesh behind the wool to hold it in place, and it held but I didn't have that much wool in there.
Right now I'm thinking about adding a Moroso resonator. It's only 4" in diameter and should give enough db reduction. I'll probably add steel wool again, just to make sure.
Fast GTO
Post subject: Posted: Tue May 15, 2007 5:19 am |
Joined: Sun Sep 26, 2004 4:12 pm Posts: 404 Location: Schweinfurt Germany
You need to take your car somewhere other than the Ramstein area......
_________________ 2003 Cobra Current Modifications: 2.2L KB (Race 20psi = 632rwhp / 592rwtq; Street 18psi = 626rwhp / 564rwtq) Full Bassani Exhaust AEM Meth Injection
a10beav
Post subject: Posted: Tue May 15, 2007 6:40 am |
Like where? Is Spangdahlem any better?
TurboManiacal
Post subject: Posted: Tue May 15, 2007 9:21 pm |
Joined: Tue Sep 21, 2004 12:43 pm Posts: 963 Location: Mannheim
Don't let the inspector do it is all I can say.
_________________ 2008 BMW 335xi
Fast GTO
Post subject: Posted: Fri May 25, 2007 1:28 am |
Try to find an Army base.
I know Schweinfurt is easy, my Goat passed.
a10beav
Post subject: Posted: Fri May 25, 2007 11:34 pm |
I actually failed the inspection at Vogelweh, is the Ramstein shop the same?
I just got a Moroso spiral flow that I was going to add to the I-pipe, they're supposed to be low resistance but reduce the db by 7. I hate to add it, but I am tired of the "rifling" during deceleration, so maybe this will help...
KC10A
Post subject: Posted: Sat May 26, 2007 9:23 am |
The Vogelweh inspectors are a bunch of a$$holes. Ramstein isn't that bad.
_________________ 2002 35th Anniversary Limited Edition Convertible with CME and SLP Induction
TurboManiacal
Post subject: Posted: Sat May 26, 2007 4:32 pm |
I'm up next...my car's not that loud...should be okay.
Kenkaru
Post subject: Posted: Fri Jun 22, 2007 9:07 am |
Joined: Mon Aug 22, 2005 12:57 am Posts: 52 Location: Mannheim
I installed a silencer in the I-pipe and then stuffed a bunch of steel scrubby pads in there upstream of the silencer. It was so quiet, they didn't test me 2nd time through.
Plugging up one of the tailpipes makes a large reduction also.
TurboManiacal
Post subject: Posted: Mon Jun 25, 2007 6:08 pm |
TurboManiacal wrote: I'm up next...my car's not that loud...should be okay.
Stock LS1 w/ Resonators = 96db - 1 over the limit (Mannheim allows 95 for whatever reason) So steal wool time.
Garry
Post subject: Posted: Mon Jun 25, 2007 6:46 pm |
Hm ... just noticed this weekend that at idle, my Firehawk (stock all the way through) is actually a bit louder than Roy's SS ...  First time I was able to see Roy move his car without hearing it!
So I reckon it would most likely not pass the US inspection ...
a10beav
Post subject: Posted: Mon Jun 25, 2007 7:13 pm |
You don't have the SLP Loudmouth installed, do you?
I have the spiral flow in teh I-pipe now. It still sounds Ok and it has taken care of the rifling, but I miss the more aggressive sound.
Garry
Post subject: Posted: Mon Jun 25, 2007 7:48 pm |
Nope, Stock Firehawk exhaust ...
Chevroletfreak
Post subject: Posted: Mon Jun 25, 2007 8:52 pm |
| No Life |
Users browsing this forum: No registered users and 97 guests |
