NXZ28
Post subject: Got the deal of a century ***Tested er' out*** Posted: Tue Jun 05, 2007 4:39 pm |
I just scored a two month old 12 bolt rearend for my car for $1200 and my old rearend. This is a direct bolt in for my car. I will be so relieved at the track now when I spray it out of the hole. I am now going to drop some weight out of the car, up the shot a little, and get me a 9 second pass. Well, that is the plan anyway.
Garry
Post subject: Posted: Tue Jun 05, 2007 5:11 pm |
Congrats ...
Daddy
Post subject: Posted: Tue Jun 05, 2007 6:13 pm |
Was this the guy on GaFBA?
You should have kissed him cause you damn sure f*cked him
NXZ28
Post subject: Posted: Tue Jun 05, 2007 6:56 pm |
I didn't twist his arm. He is selling the car because his second motor just blew. He needs some cash and he isn't going to need the rearend anyway.
Fast GTO
Post subject: Posted: Fri Jun 08, 2007 10:55 pm |
Joined: Sun Sep 26, 2004 4:12 pm Posts: 404 Location: Schweinfurt Germany
Good "He said POOP", let us know when you get that 9 second pass.
Just had my ported 90 FAST and TB installed. Tomorrow Nicole takes the car to get tuned during the MM dyno day.
_________________ 2003 Cobra Current Modifications: 2.2L KB (Race 20psi = 632rwhp / 592rwtq; Street 18psi = 626rwhp / 564rwtq) Full Bassani Exhaust AEM Meth Injection
NXZ28
Post subject: Posted: Mon Jun 11, 2007 3:54 pm |
I got the rearend in this past weekend. It is alot bigger and heavier than the little 10 bolt. It has 4.10 gears in it. I also have a steel drive shaft with the 1350 u-joints now. I am ordering the 250hp jets this week and try it out if a few weeks in the 1/4.
What kind of numbers did you put out on the dyno? Just remember that dyno numbers don't mean squat to an automatic car. The converter and tranny eat up alot of the power.
Fast GTO
Post subject: Posted: Mon Jun 11, 2007 11:32 pm |
Its a mustang dyno and I got 378rwhp actual from the dyno.
The tuner said it is around 408rwhp/375rwtq on a dynojet.
And he said the same as you regarding the performance and torque converter etc...
Should be good for low 12's now, pulled strong to 6500rpm and the ported FAST is a huge difference in the upper RPM's as witness by an 04 MACH 1 that Nicole squashed from a 100MPH roll.
NXZ28
Post subject: Posted: Tue Jun 12, 2007 7:19 pm |
D@mn good numbers. Now here is a good question. Once you get to the low 12s, what are you willing to do to get to the 11s? A 100-150 shot would be nice on the car. Or you could pull the motor, put in forged pistons and rods, and put a direct port on it. It would run a high 10 on a 200 shot. Of course, the car gets a few rattles in it the faster you go.
Daddy
Post subject: Posted: Tue Jun 12, 2007 7:47 pm |
NXZ28 wrote: Of course, the car gets a few rattles in it the faster you go.
Then the floor board falls out!
NXZ28
Post subject: Posted: Wed Jun 13, 2007 8:53 pm |
Daddy wrote: Then the floor board falls out!
Or your shopping cart wing falls off.
SRZ
Post subject: Posted: Thu Jun 14, 2007 7:36 am |
Jason you just got blasted! Ha-ha!
_________________ The "SRZ" 750rwhp, limited to 55mph flyby's in the US. 02' MY Z06, Cam, LT headers, X-pipe, Breathless CAI, Borla Stinger exh, RSD short shifter, Elite catch can, C6Z susp, CCW classic's 18x10 & 18x12...your normal everyday Z06.
Daddy
Post subject: Posted: Thu Jun 14, 2007 11:07 pm |
NXZ28 wrote: Daddy wrote: Then the floor board falls out!  Or your shopping cart wing falls off.
Plenty of duct tape holding it on!
What are you talking about Silas? I got the same jack stand mod you do
SRZ
Post subject: Posted: Fri Jun 15, 2007 7:17 am |
Daddy wrote: NXZ28 wrote: Daddy wrote: Then the floor board falls out!  Or your shopping cart wing falls off.  Plenty of duct tape holding it on! What are you talking about Silas? I got the same jack stand mod you do
We don't have that in common.
KC10A
Post subject: Posted: Fri Jun 15, 2007 1:49 pm |
Since when, Silas. I'm still waiting to see your car alive again.
_________________ 2002 35th Anniversary Limited Edition Convertible with CME and SLP Induction
SRZ
Post subject: Posted: Sat Jun 16, 2007 9:55 pm |
Jerry.  It's up but the base tune isn't something I'd drive on. I've got some minor tweaking to do and I'll be on the road. I was hoping to have it up for Bitburg this coming wkend but it doesn't look like it unless I get my part from Summit before the weekend....bad -an fitting of the fuel rail. I've been on fire before and I'm not doing that again.
I will be out for Bitburg in July.
Daddy
Post subject: Posted: Mon Jun 18, 2007 2:51 pm |
SRZ
Post subject: Posted: Mon Jun 18, 2007 6:39 pm |
Thanks. I've got a quick vid but it's 85mb and I don't know how to compress it. I am not a techi kinda guy.
NXZ28
Post subject: Posted: Tue Jun 19, 2007 7:18 pm |
Well, I took it to the 1/8th mile track this past weekend. I took a little weight out of the car. It went 7.39@92 on motor and 6.74@103 on the kit. The rearend is awesome. I am still spinning a little when the kit comes on. I am also about to lose 3rd gear. It is not wanting to shift at all on the kit. I bet this car has a 6.5X in it if the tranny would shift.
Daddy
Post subject: Posted: Tue Jun 19, 2007 8:17 pm |
What does a 6.5 equate to in the 1/4?
98 T/A raptor
Post subject: Posted: Wed Jun 20, 2007 8:07 am |
Joined: Tue Aug 17, 2004 11:24 am Posts: 501 Location: sembach germeny
10.075. All you have to do is multiply his time by 1.55. Looks like that 9 second time slip is in reach.
_________________ 98 Trans Am
Users browsing this forum: No registered users and 31 guests |
