It is currently Mon Aug 24, 2026 1:35 pm
 Post subject: 91 F-150 2wd 6 banger $500 the way it sits
PostPosted: Tue Jun 19, 2007 6:20 pm
It needs a new clutch master cyl, and line ( for a 95, long story) or if you can flare the plastic lines a make a new one. Front brake pads, and a little welding on the muffler and a drivers side mirror. The ignition switch was fubbared, so the key is a screwdriver. This is in no means a pretty truck, but it is dependable. I'll take $400 the way it sits, and no it will not pass inspection.
pics in about 20 mins
FYI, I have 5 vehicles and need to get rid of some, so says the area commander.
PostPosted: Tue Jun 19, 2007 6:22 pm
do ya have some pics of it?
PostPosted: Tue Jun 19, 2007 6:23 pm
Ups soory read about the pics later so what cars do ya all have up for sale?
PostPosted: Tue Jun 19, 2007 6:24 pm
just the truck and the opel....loading pics onto photobucket now, should be about 10 mins
PostPosted: Tue Jun 19, 2007 6:28 pm
PostPosted: Wed Jun 20, 2007 5:09 pm
Bump...I'll take 300
PostPosted: Fri Jun 22, 2007 10:19 am
Hmm... i guess it's not driveable then and needs to be picked up on a trailer?
PostPosted: Fri Jun 22, 2007 10:23 am
Are you getting into the Car business Jens?
PostPosted: Fri Jun 22, 2007 10:33 am
J E N S?
PostPosted: Fri Jun 22, 2007 11:32 am
Sorry ;) Read Jens' request about the 98 Formula, then your post and joined them ;)
PostPosted: Fri Jun 22, 2007 7:05 pm
I can make it drivable for a few days.....it;ll take about 150 bucks of work and parts to get it good. If it doesnt sell before I leave on monday, I will p[ick up the parts in the states and fix it when I get back,...then sell it for about 700 bucks
PostPosted: Tue Jul 17, 2007 12:58 am
ok, Update:
I bought the clutch master cyl and line needed to fix the darn thing. I also got brake pads. I will install those parts and put in a push button or toggle ignition switch. All the truck will need for inspection after that is a mirror and a small weld job on the pipes, which I may get fixed too. $700 OBO. Has 2 brand new tires on the rear, clutch has less than 1000 miles on it too. SERIOUS OFFERS ONLY!!!!!
PostPosted: Thu Jul 19, 2007 5:46 pm
anyone?
PostPosted: Thu Aug 09, 2007 6:18 pm
truck is getting registered non op tomorrow.....$500 the way it sits
mods, can u change the title to reflect $500
BTW, all parts are installed minus the ignition.
PostPosted: Thu Aug 09, 2007 9:23 pm
Jim, why you trying to pawn off all your junk on us? Nobody wants a FURD over here...well w/ the exception of a Cosworth. :D
PostPosted: Fri Aug 10, 2007 4:47 am
at least it runs :D
