It is currently Sat Oct 24, 2026 4:34 am
 Post subject: Phoogle Map?
PostPosted: Fri Aug 17, 2007 5:48 pm
Just see on the top "phoogle map". What is this?
PostPosted: Fri Aug 17, 2007 6:00 pm
You're too quick ...
Just added this mod to the forum ... everybody can select their location in the profile, locations will be visible on the google world map ...
PostPosted: Fri Aug 17, 2007 7:16 pm
I can't figure it out. It isn't working for me, but I see Gary on there.....just no map.
PostPosted: Fri Aug 17, 2007 7:39 pm
Go to "Edit Profile", then enable to be seen on the map ... then center the map on where you are located ...
PostPosted: Fri Aug 17, 2007 8:00 pm
Cool! I'm on.
PostPosted: Sat Aug 18, 2007 12:17 am
PostPosted: Sat Aug 18, 2007 5:24 am
Hm ... OK Google Maps is too stupid to understand that http://www.fbodyeurope.org and fbodyeurope.org is the same site ... :(
Edit: Looks like I fixed it ... selected the www. address instead, and it still works w/o the www in front ...
PostPosted: Sat Aug 18, 2007 6:35 am
I can't zoom unless I use the wheel on my mouse. It scrolls the screen at the same time as well. I got it done though.
PostPosted: Sat Aug 18, 2007 8:28 am
Thanks, very cool.
PostPosted: Sat Aug 18, 2007 12:58 pm
that is cool. Thank you Garry.
PostPosted: Sun Aug 19, 2007 2:52 pm
just as a quick info on how to set yourself up:
Go to "Edit Profile", go to "Show My Marker on the Phoogle Map" and select "Yes", then center the map beneath it (increase magnification for better accuracy) and save the settings. Once you're through, an icon should appear in the overview ...
I will put in two logos, a Chevy & a Pontiac logo, for more accurate markers ;)
