Page 1 of 1
[ 14 posts ] |
BenZ28
Post subject: 996tt brake setup opinions? Posted: Thu Sep 13, 2007 9:26 am |
This goes especially to Roy:
Any opinions to the Prostop 996tt brake setup as offered on frrax.com?
How does it compare to your Movit system, is it superior or inferior?
SRZ
Post subject: Posted: Thu Sep 13, 2007 2:15 pm |
Basically the same setup (Brembo).
Post subject: Posted: Thu Sep 13, 2007 6:59 pm |
BenZ28
Post subject: Posted: Fri Sep 14, 2007 9:34 am |
What kind/size of wheel spacers do you use, Roy to fit the brakes?
Post subject: Posted: Fri Sep 14, 2007 3:04 pm |
BenZ28
Post subject: Posted: Sun Sep 16, 2007 9:54 am |
The 996tt kit requires a 25mm spacer PLUS an additional spacer before the rotor mounts to the hub.
Garry
Post subject: Posted: Sun Sep 16, 2007 10:49 am |
WWTS?
(What would/will TÜV say?)
Post subject: Posted: Sun Sep 16, 2007 12:27 pm |
BenZ28
Post subject: Posted: Sun Sep 16, 2007 2:08 pm |
The Movit is more expensive with similar hardware. TUeV for the other kit could be done I guess.
The spacers thing is what makes me think. I don't like them... generally.
Roy, what is the weight of your Movit stuff, i.e. calipers, pads, rotos compared to stock? Is yours much heavier?
Post subject: Posted: Sun Sep 16, 2007 2:45 pm |
BenZ28
Post subject: Posted: Tue Oct 02, 2007 11:02 am |
With the 996tt setup and those spacer, you need new wheel studs.
Now, let's assume we take a STOPTECH kit which would need as the only spacer a 10mm one (I'm not 100% sure but that doesn't matter right now). Would I also need new wheel studs with the 10mm spacer?
I also found the H&R DRM TRAK+ spacer which looks like it has built-in new wheel studs...?
Post subject: Posted: Tue Oct 02, 2007 7:09 pm |
BenZ28
Post subject: Posted: Tue Oct 02, 2007 8:55 pm |
OK.
Roy, can you take a look at this:
http://www.h-r.com/index.php?inhalt=pro ... sprache=de
The DRM system should be for our cars. It looks like that spacer is mounted on the "old" wheel studs and has built-in new studs. Can this work? I mean, aren't the old studs subject to forces that may lead to their failure with this system?
I don't quite understand that...
Post subject: Posted: Wed Oct 03, 2007 5:23 am |
As long as the spacer is hub centric it should be fine. BUt Ireally wouldn't want to be putting the stresses of Hockenheim through them.
Page 1 of 1
[ 14 posts ] |
Users browsing this forum: No registered users and 21 guests |
