It is currently Tue Aug 25, 2026 8:30 am
 Post subject: Help 911
PostPosted: Thu Oct 25, 2007 2:02 pm
Ok the bird is at Kapaun right now but those dipsh!t$ that shipped it got my key fobe wet and it corroded inside. (i cleaned but no luck) when they went to get in they tripped the stock alarm.......
WHAT DO I DO??? I have a spare keyfobe BUT i didn't have enough time to cal. it to the car before I shipped...if I try to cal. it now will it work???
My wife is due in two weeks and the Dr. today said that they will induce in 1 1/2 if she doesn't diliver on here own so I NEED my car now even if it does fail for DB.
can I reset my computer by disconecting the batt. and it work or what???
PLEASE help
PostPosted: Thu Oct 25, 2007 2:32 pm
I cannot get to the site at work, but it will not hurt to try and program the new one. Did you try the alcohol to clean it?
PostPosted: Thu Oct 25, 2007 4:45 pm
Your alarm should deactivate once you put the key into the ignition and turn it on.
PostPosted: Thu Oct 25, 2007 8:48 pm
It won't help you out real quick, but you may want to try partszoneonline.com. Bill Markovich might be able to get you a new key fob for your security system if you can give him the VIN. He is a great guy to work with and has good prices. If he can get one, he would Express Mail it to you in that would help.
PostPosted: Thu Oct 25, 2007 9:26 pm
thanks for the help so far.....
Bus...the cleanig didn't work
If I can get away tomarrow I will try disconecting and reconecting the batt. and reset everything...... i also think after looking a the part # on the new fobe that it wont work cause the numbers are off...they look the same....the guy I bought it from said it was from a 00' camaro.......
well off to bed so I can get up in three hrs for a long weekend
PostPosted: Fri Oct 26, 2007 5:56 pm
40 euros should get you next day service from the US and a key in your hand.
