It is currently Fri May 01, 2026 8:02 am
 Post subject: Type of exhaust
PostPosted: Fri May 09, 2008 4:36 pm
What kind of exhausts are you guys running? I'm looking changing my exhaust soon. I've still got the stock exhuast and it sucks. Post up what you got and how many db's it registered. Thanks.
01 TA-M6-Blue
 Post subject: Re: Type of exhaust
PostPosted: Fri May 09, 2008 5:44 pm
SLP LM
Not recommended
Depending on the car it will be definitely over 100 decibels mininum.
PostPosted: Fri May 09, 2008 7:51 pm
Emmissions delete
Kooks Lt's w/ 3.5" collectors
ORY
Borla closed off
98.9 db (dang sooo close)
PostPosted: Fri May 09, 2008 9:05 pm
Pacesetter Long Tubes w/ catted Y-pipe and stock exhaust ... no idea yet, will hear it tomorrow ;)
PostPosted: Fri May 09, 2008 9:57 pm
Not and F-body but I use Supertrapps, always have.
PostPosted: Sat May 10, 2008 1:48 am
I'm looking to upgrade my exhaust so I was trying to get an idea of how high of db's you guys are getting with your exhaust setups. Thanks to all of those that have chimed in.
I've currently got hooker ceramic lt's and a tsp cat'd y pipe with stock exhaust.
01 TA-M6-Blue
PostPosted: Sat May 10, 2008 10:38 am
The great thing about the trapps is that you can tune the system as you need.
PostPosted: Sat May 10, 2008 1:58 pm
Borla with an electric plate. Can adjust from quiet to not so quiet with a switch from inside the car.
PostPosted: Sun May 11, 2008 12:44 am
BenZ28 how many db's did you register with the borla exhaust?
01 TA-M6-Blue
PostPosted: Tue May 13, 2008 2:34 am
Does anyone know how many db's they got with their exhaust?
01 TA-M6-Blue
PostPosted: Tue May 13, 2008 9:17 am
I don't know the exact numbers for "closed" but it should be well below 90 dB.
PostPosted: Tue May 13, 2008 11:22 am
At idle? :D
PostPosted: Tue May 13, 2008 4:36 pm
I was thinking that exhaust was louder than that, but if not than that sounds like a good exhaust to go with. Does anyone else know how many db's they registered with their exhaust?
01 TA-M6-Blue
PostPosted: Tue May 13, 2008 5:51 pm
I've got the GMMG cat-back and I love it. Little loud though. Took two bags of steel wool and my wife in some tight jeans to get it passed. Makes it sound like an old muscle car. I definitely wouldn't recommend it with LT's and no cats. They don't make enough steel wool to quieten that much.
PostPosted: Tue May 13, 2008 8:50 pm
Well I have cat's now so I'm looking for something that's better than stock but will still pass the db check. I have a friend here that has the GMMG exhaust and it does sound good and I like the borla sound too but it seems like it will be way to loud.
01 TA-M6-Blue
PostPosted: Wed May 14, 2008 9:11 am
Not when the Borla is closed.
