It is currently Mon Aug 24, 2026 8:23 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Oct 10, 2007 12:22 pm
ah okay we thought you might be in the states......
PostPosted: Wed Oct 10, 2007 3:15 pm
Nope not till the 1st.
 Post subject: Re: it fits sofar.....
PostPosted: Tue Nov 11, 2008 7:56 pm
finally found the needed axle
8.8 with lsd and c clip eliminators and moser upgraded axles :P
first gear with the T56 should get me to 100km/h at 6300 rpm :ok:
so we should see some acceptable 0-100 times
this is an original commodore gear
PostPosted: Tue Nov 11, 2008 8:11 pm
Looks like your making progress. That c-clip eliminator is scary. Is it made for the street or for just drag racing?
PostPosted: Tue Nov 11, 2008 8:18 pm
Congrats ... guess that should be able to take a beating without breaking ...
PostPosted: Tue Nov 11, 2008 8:19 pm
euh well you got me there, i have no idea :?: although it can't be much bigger in diameter otherwise it would hit the drumbrake hydraulic actuator
PostPosted: Tue Nov 11, 2008 8:46 pm
Every C-clip eliminator I seen , had a warning not for street or roadcourses. This was due in part to the excessive side loads generated that made the c-clip elimator fail. The two main failures are bearing failure and bearing retention on the axle.
Be careful man
PostPosted: Tue Nov 11, 2008 10:20 pm
Good you mentioned it.
What i will do is, to make sure if the bearing retention fails (the halfshaft can only go inwards the diff-carrier) make the end of the halfshaft to be VERY close to the pin (sattelite wheel retentioner) so not much can happen
i can do this because i shortend the axletubes, as much as the splines on the moser axles let me. :roll:
Thats the best i can do that i can think off ( i don't have a safe feeling with the c-clip setup either)
