It is currently Wed Sep 09, 2026 12:25 pm
 Post subject: serpentine pulley 6 rib of pref. 8 rib steeringpump /crank
PostPosted: Fri Feb 13, 2009 12:08 pm
looking for preferably an 8 rib serpentine pulley of aprox 6,5inch 167mm
a 6 rib pulley of simular diameter is allso better as no pulley at all :mrgreen:
no cast iron but stamped steel or aluminum, as i have to weld on it...
apparently this diameter was stock on at least bbc steeringpumps
but there are prop. plenty other applications that these were used , so please check in your garage for that old engine/ steeringpump ?
any help welcome guys !!!
thanks, Jeejee
 Post subject: Re: serpentine pulley 6 rib of pref. 8 rib steeringpump /crank
PostPosted: Sun Mar 29, 2009 4:07 pm
You have to start sending me these things by email so I can look here.
PostPosted: Sun Mar 29, 2009 9:42 pm
plans chance so quickly, that i now don't need that diameter anymore, still not sure what diameter i need as i have to do some calculations for the new setup
it may be best to start with the moderate setup and attend some bitburg events before i change to the bigger blower setup + boost that might kill the engine, and then i have nothing :bash:
PostPosted: Thu Apr 02, 2009 4:52 am
I have a spare Stang power steering pump and pulley
