It is currently Wed Sep 09, 2026 10:26 am
 Post subject: LS1 Ingnition coil ?
PostPosted: Thu May 14, 2009 8:08 pm
Not sure if it's the cause of my problem, but wondering - just in case - anybody in the K-Town/Ramstein area happen to have a stock coil left over flying around?
 Post subject: Re: LS1 Ingnition coil ?
PostPosted: Thu May 14, 2009 9:14 pm
To keep.....or borrow?
I've got a borrowable set.
PostPosted: Fri May 15, 2009 5:24 am
Garry
Are you getting multiple misfires from certain cylinders?
Just a thought here , check the main coil pack connectors. Check to ensure the spring tension clips in the female connector end are not smashed flat.
PostPosted: Fri May 15, 2009 7:19 am
Tnx both, will see what we find out in an hour or two ...
PostPosted: Fri May 15, 2009 12:49 pm
If its missing in the upper rpms and all your plugs wires and coil pack connectors are good then try and do a "Case Relearn." I had the same problem and that fixed it.
PostPosted: Fri May 15, 2009 1:36 pm
Nope, cause was just the WBO2, which is shot after all ... I thought the PCM was ignoring the O2 inputs due to the OLSD tune, but it wasn't ... with the O2 signaling lean, the PCM was dumping fuel into the 4 PS cylinders ... replaced it with one of my old NBO2, and it seems to be running fine again, both O2 sensors are pretty close to each other (apart from the LTFT which is probably still adding a bit of fuel to the PS cylinders for now ...)
So, luckily, apart from a day's work, and a dead WBO2, everything is good ...
PostPosted: Fri May 15, 2009 4:27 pm
Garry
I am glad to hear that you got fixed.
PostPosted: Fri May 15, 2009 6:46 pm
Wow Garry,
You just made me feel stupid. I think I understood what you just said. I am glad you found out what the problem is though. Can you just do the "Case Relearn" so I feel better?
PostPosted: Fri May 29, 2009 11:06 pm
Glad you figured it out Gary.
Users browsing this forum: No registered users and 16 guests
